Hello everyone
Kieran
Hello everyone I have a deep interest in vintage watches and watch repair and am trying to learn as much as I can about the subject. I normally service pocket watches but have recently started to service wristwatches too. Looking forward to hearing back from you all. ?
Kieran
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
