incabloc
gary17
Hey
Can someone explain to me how i would order a lower incabloc capor a incabloc hole jewel or the incabloc as one.
I am after a lower incabloc hole jewel i went to the list http://www.incabloc.ch/en/pieces_rechanges.php and i dont understand the french. I have the above incabloc as 103.11.312 and the lower as 100.20 but when i go to cousins those numbers are not there or i cannot find them. I have translated higher ,lower.hollow,screw ,key and then its about something about pierre and a cat (chaton is a kitten??????)
Please anyone who understands this please let me know
or has the list in good old english.
cheers
gary
Bloc dessous = lower bloc = 10.100.20, bloc dessus = upper block = 10.103.11.312.
Pierre de contre pivot = end stone (dessus and dessous for upper and lower) and they are 121.11 and 122.11.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
