Longines 506 No open spring barrel
Jakub
Hi there!
Yesterday I started tear down of Longines cal. 506. Nice movement, but found this main spring barrel that has note “Do not open”.
I am no experienced watchmaker and so I maybe should follow such a instructions, but I’m also curious.
My question is, is there way how to open and then safely close barrel of this kind? What is potential dangers, if yes?
If not, how to service such a part without opening?
Regards
Jakub
1 hour ago, Jakub said:
Hi there!
Regards
Jakub
Of course you can open it simply by pushing the arbour and placing the barrel on a holder or tweezers.
I think the theory behind sealed barrels is the fact that the parts, barrel and spring take quite a lot of stress during operation so therefor if you need to change the spring then also change the barrel. This in effect eliminates any problems just putting a good spring in a worn barrel and it is a one step operation. Not only that you have to buy the barrel and spring (greater cost). The barrel can be opened as poljot says and done carefully would probably be ok, but bear in mind some of the longines barrels were greaseless and greasing them lowers the power reserve due to  excess slippage.  so in effect you take the chance.
The link to the other thread above is about a Zodiac barrel, which you very definitely don't want to open unless you want to search for another- or make a new cap. As I recall the Longines "do not open" can indeed be opened, it's been a while since I did one but I think the cap fits "over" the barrel, like a 7750 cap, and it's good to lift it off starting with a thin blade working around the rim. If you just push the arbor the cap has a tendency to actually grip harder as it bows.
Big thanks to everyone who chipped in, big help indeed.
Alright I hear you all. Now after reading the thread posted above (thank you @Poljot) and all other posts. I came to conclusion and this is what I going to do...
Clean the rest of the watch and barrel exterior will get “peg & rodico treatment” and arbor D5 in place where it meets barrel. After assembly put it on timegrapher and see what’s up. I guess mainly focusIng on amplitude.
The movement is clean, no oil paddles and no service marks. Barrel itself is nice and clean, no old oil black stains. So I will hope this works. If don’t I gonna get down to open it up.
Tomorrow I’ll get to assembly, and will let you know how did it worked out.
I feel like posting a picture of watch in parts ?
Cheers!
Good evening guys!
So after work right behind watchmaking desk. I did exactly as I sad. Once I’ve put it together and tiny tweak, here is result from all mighty Weishi No 1000. Think I leave it that way.
One more time thanks for all inputs.
Cheers
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
    • @Murks the problem you have mate is most watch cases out there to buy are for Seiko NH3X, ETA 2824 and maybe Myota 8XXX movements, oh also the big ETA 6978/9 movements which the dials start around 28.5mm. You might find one on a Google search but I suspect your main chance will be buying cheap quartz ladies watches and hopefully find one of the right size and condition that is acceptable. 😞   Tom
    • The anchor pin should be perpendicular when the anchor is sat on a flat surface and if you post a close up picture of the backplate I will be able to tell you the correct torsion spring , running fast or slow is usually wrong Torsion spring. Here is a video from my YouTube channel showing how I set the beat
