Rolex 3135 movement -in over my head?
IBM16220
2 minutes ago, Tudor said:
If the tip of the seconds hand pinion broke off inside the original seconds hand, a new hand will not help completely- you will need to replace that seconds hand pinion as well, so the new hand has something to attach to.
What did you end up doing to secure the dial?
Thanks for the input. The second hand pinion was the reason for this whole saga. I bought a new second wheel where the pinion is attached. I then decided after watching YouTube videos i was ready to replace it myself. ?
For the dial i ended up buying a pre owned one that had the feet and just replaced the dial.
