Snapped date and time stem - Rotary
AndyT
Hi,
Thanks again and its nice to be here.
I've managed to snap the stem on my date and time adjuster on my Rotary Chronospeed. Its not expensive, more sentimental.
GS03351 /19 (12881)
Could anyone post a link to replacement?
Thank you so much for any help
The case reference is not important, you need to look at the identification on the quartz module. For the best results I recommend you give it to a watch shop, it should not be an expensive repair.
I may need to correct myself. For an easy repair the crown stem must be of the threaded type and the repairer able to remove the stump from the crown - but I can't see enough about this in your picture. There are good techniques to do that, but if he won't  be able to, he will want to replace the crown as well, which being of the screw on type may be difficult or impossible to find  identical to the original. You might even hear about the claimed need  to replace the pendant tube as well, and be given an estimate higher than the material value of the watch. Good luck.
Hi  For your information   the whole  Miyota OS20  movement costs £15 from Cousins, they usually come with a stem attached. All you need is to recover the crown. If the crown is brass this can be done by dissolving the broken steel stub in a solution of ALUM which will eat the steel but not the brass.
I have seen "alum" mentioned several times for this purpose.  My googling yields several types (potassium, ammonium). Which kind do you use?
Thanks everyone
I've managed to remove the broken stem from the crown and also released the snapped stem from the watch internal.
I've picked up a new stem for £5 and job sorted.
You guys are awesome ?
Very good. Because of the screw in crown measuring the stem before cutting is a bit more complicated. If you will want, ask here when you're ready and I'll tell you my method. I also recommend that you use a mild locking agent on the crown.
44 minutes ago, AndyT said:
Oh no! I thought it was just a straight forward stem replacement.  I had no idea that it had to be cut!
Is the crown end that needs cutting ?
That's why I was recommending you bring the watch to a repair shop. One that is totally new to watch repair can't know how things a correct and doesn't have the correct tools.
However since no recommendation can prevent people from doing whatever they want to their property, here a relevant video by our Host Mark Lovick. Note that doesn't cover the extra measuring steps needed with a screw in crown.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
    • Could you glue two pieces together for rigidity and separate after forming?
