Hi all
Sanjeev
Hello everyone. I am relatively new to the wonderful world of watches, my passion being antique pocket watches. I live in Germany and have a collection of American pocket and railroad watches, and a collection of European fusee watches. I am fascinated by the combination of art and technology these watches embody, and would like to investigate their working. I have made tentative steps in dismantling a non-working movement and my initial aim is to completely dismantle a watch and re-assemble it again.
