Automatic clicking
chrisdt
My Garrard Automatic has developed a loud click at almost every turn of the crown when hand winding. It appears to collect power ok though and also auto winds correctly and keeps working whilst wearing. I have taken the rotor off but have not been able to locate the source of the problem. Any assistance as to where I might start looking would be appreciated
I'd be tempted to take the winder module off too, to see the click, rachet and winding wheel. You not only  have eliminate the parts you removed but might even see the fault starring at you, also wind through rachet wheel, that eliminates quite a bit for the least.
Its a process of elmination, next I guess is checking under dial.
Good luck
Does your watch have a caliber number? Then it almost looks like is a number under the balance rim that would be helpful if there's a number there? We might bill a find a tech sheet perhaps.
Then we can guess because we can't see the automatic mechanism so that probably has to come off. It may be that the reverser wheels have gotten sticky with time but that's just a wild guess. Also the other problem with automatic watches is often times they did not use jewels in critical locations and the holes where out to get oval. So basically this is exactly as mentioned above problem solving and you're going to have to take the automatic mechanism off. Then carefully look at all the wheels all of everything and you should build figured out hopefully
It's always amazing what you can find online if we take the movement number and the name they come up with the links below both of which suggests that the movement is based on  ETA 2783. From that we can a parts list.
https://antiques-atlas.com/antique/gents_unusual_1970s_silver_wrist_watch_garrard/as170a7214
https://www.birthyearwatches.com/product/1974-garrard-9k-gold-automatic/
496_ETA2750,1,2,6,4 ETA 2783.pdf
Thanks JohnR725 for that connection... I must say the gold Garrard which is the same as mine seems rather expensive at £449. I sold 2 of mine last year at less than half that price. But I suppose that is why they stay on sale for month after month after month
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
