Dashboard clocks EA1-EA31 Smiths
transporter
Good morning everyone, hope you are all well, quick question if i may, I have a smiths dashboard clock that is in need of a new escape wheel ( broken lower pivot ) mines an EA1, I’ve seen loads of EA31 platforms on eBay and have been unable to find any information on wether the two platforms or just the escape wheels are interchangeable? Has anyone here any experience on these Movements please that could help me out?
many thanks in advance
6 hours ago, oldhippy said:
I'm assuming you can't re-pivot the wheel.  I would go for a replacement platform, just make sure the leaf count is the same, that is the the teeth on the escape wheel.
I’d love re-pivot it mate but I don’t have the drill press attachment for my lathe tail stock ( 6mm lorch ) so re-pivoting is unfortunately not possible.
Would I be correct in saying the leaves  are on the pinion and not the escape wheel itself?
well hopefully eBay will produce, I have seen a few for the other movements EA31’s but none so far for EA1’s, I’ll message the sellers anyway to see what the leaf counts are. Cheers for the help
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
