Hi I got this watch in a job lot but I’ve been unable to identify the movement. The only numbers are 411.7 on the plate and 7 under the balance. I like the look of the watch so would like to repair it. Any help identifying the movement would be appreciated. An opinion on the dial would also be appreciated, the crown and lettering look ok to me but I’m certainly no expert. There are service dates on the dial and case but I can only really make out one which is in 1944. thanks
Search for the barrel diameter vs the length and make sure you have the height correct and strength close (thickness.)
Its looking like the bike I rode to work on in the 60s although mine had straight bars and mudguards, needed them in the UK, Like the tires though Just finishes the look. Saddle looks comfy not like the razor blades of today, Nice that the sturmey archer is working good Had some sore parts when they slipped up hill, Is the paint work original as it looks in good nick. -
I am looking for a “holed” replacement mainspring (without bridle) for an old fusee pocket watch and a fellow forum member pointed me towards one on the cousins website. https://www.cousinsuk.com/category/filter/mainsprings-by-size-watch-pocket Two issues: First, the spring is simply listed as “non-automatic” and doesn’t say how it is terminated. However...... Second, the spring is substantially longer than the original, the original spring was roughly 410mm and the cousins one is 580mm. Are mainsprings easy to alter, maybe snip the spring down to size and drill or punch a hole in the end?
Question
Robbie010 6
I started playing with my latest project today, carefully stripping down and cleaning each piece individually, I came across some minor surface rust. I soaked the parts in degreaser and initially went at the part with peg wood to loosen the surface. I then re-cleaned them and had a go with a fibreglass pen before cleaning again and soaking in oil for 10 mins.
The results look ok under general magnification but not so great when looking closer.
How far should one go with such surface rust and what would be the correct next step in dealing with it??
Thanks.
Link to post
13 answers to this question
