Remove calibre from back plate
Birdie
I hope someone can help me here please. I have bought a Trafalgar watch from the bay which is a front loader and I cannot remove the works. I have managed to remove the bezel and dial etc but the works are still very secure in the body. I can’t see any securing screws and don’t really want to use any excessive force. I have attached photos. Would very much appreciate any guidance.
There seems to be two areas that might be impinging on its release. The stem seems to be rubbing on the case also not sure what the other area I have ringed is.Also do I see a seal surrounding the movement.
I recommend the stem and seal is removed and try to wriggle it fee.
Nickelsilver. Thanks for response, I have tried that. There even appears to be a small cut out to help but it won’t budge.
Clockboy. Thanks for the response. I thought the same, in fact I thought it was a kind of circular spring, but on close inspection under the microscope it is actually part of the body. The stem part is part of the crown and rotates easily. I think as Nickelsilver suggest it is probably just stuck. I’ll try a bit more force.
Thanks again for all your help.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
