Demagnetizer Recommendations
Don
I've got a movement that I think is magnetized. The hairspring coils are sticking and it makes a compass needle jump when placed over it. Here's a pic of the timer reading:
I've watched Mark's videos and so I'm shopping for a demagnetizer. I'm looking at the Etic for about $80 shipped, the similar C&H model for about $30 shipped, the generic clones for $10 or so from China, this bad boy from Amazon (too heavy duity?) and some vintage Vigor demagnetizers. I'm a little (a lot) tool nutty and I hate buying really cheap and then spending again for one that works. Any recommendations?
Also, just for fun I was playing with the super slow speed function on my camera last night and made this video. Not great quality, but may be of interest.
https://youtu.be/JpLEB0kiHw0
Thanks,
Don
If you can afford the Etic, then go for it - I melted mine by leaving it plugged in and mistakingly setting a book on top of it which pressed the button down :D
I since purchased one of the Chinese ones to see what it was like and it works just fine.
The Elma I have in my video is an electronic one and it is good but IMO seems to do no better than the cheap chinese one, it is just very convenient to use.
I was going to get one of the Chinese ones as my next tool purchase.  The 3 Dumont tweezers I got from my watchmaker desk purchase are all magnetized so I defiantly want to fix that so I can start using those great tweezers.
Thanks for the input Mark. I got the Etic for about $68 shipped. Assuming it's in stock, I'll have it tomorrow or the next day. I'll keep it away from books and I'll update this post when I get to use it. :D
Blake, how's the bench? Did you re-stain it?
I'm leaving the stain till the end.  I have one of the drawer fronts that is trashed and another that has fallen apart and will need a few pieces replaced.  I got my father-in-law's router for this but need to buy the correct bits for the recessed drawer pulls.  Once I have those sorted I want to replicate the rails that would have originally be on the sides an back to hopefully catch pinging parts then move on with the stain.
Nice! I hope you'll post the finished piece when you're done.
Hi Roger, that was the first type that I purchased. It's very easy to use, hold the watch over the flat part above the switch and light, press and hold the button while slowly moving the watch away from the demagnetiser to a distance of about 800mm, then release the switch.
Sometimes you have to repeat it a couple times to get the correct result, but it does work.
Probably where i did wrong . I didn't now i needed to remove it slowly from the demagnitiser . I do now .
I bought this one from eBay - item 330738537038 (more in stock) from HK.
It is half the price of the identical item from Cousins and one-tenth that of the seemingly equivalent Bergeon 2321.
One minor problem is that to follow these instructions from Bergeon and Cousins you need three hands:
Slowly pass the piece to be demagnitized through the apparatus, and take it out the other side.
Repeat the operation several times, always in the same direction.
Press the button during the entire operation.
The only solution for me is to fix the item to a long  strip of cardboard and then pull it from one side to the other through the hole while pressing the button, ending up about one meter away. This works a treat. The great advantage over the flat-bed type is that it can demag much larger items
Edited by cdjswiss
  • 1 year later...
I am working with an NMR spectrometer which is 94000 Gauss :) Sure my watch was magnetized, it even stopped once i forgot to take off before going close to the magnet. Since i had a suitable transformer and remaining wire from generator rewireing decided to put together a demagnetizer yesterday. Used the middle of an empty bottle as the coil shape, it is big enough for all sized watches, even for my Roskopf pocket watch :) The 230V/60Hz main current is transformed to 12V/60Hz with a toroid transformer. The wire is 0.7mm in diameter and four layers were wound. It is connected directly to the transformer... well, burned some 800mA fuses when connected to quickly with a switch :) but working fine with a crocodile forceps. The copper layer under it is for cooling. It is heating up over 60 Celsius in 30 seconds.
Before demagnetization the gauss meter (android app) shows up to 3 Gauss.
The peak is only 0.34 Gauss after demagnetization :) The rate increased by ~10 s/d, amplitude is the same and it is more stable in the different positions.
Finally demagnetized all of my steel tools. Never again sticky screws :)
Edited by szbalogh
de  magnetize /  de GAUSS :  I have a couple old watchmakers de magnetizers.  there is a button to  hold down  when  passing AN   ITEM  thru  (in and out)  of the coil.   this  means  there is  no  power on when  left un attended.    I  like that  GAUSS  meter.  vlnn
21 hours ago, oldhippy said:
You are right, the beat error increased a bit from around 0.3 to 0.5 - 0.6ms. I will introduce some light bulbs to the high Voltage side to reduce the power.
The magnetic sensor in my smartphone is on the top right corner of the display. Google says that usually it is in the top left corner. You need to place the watch directly over the sensor to measure this small fields.
Edited by szbalogh
the proper tool  is  a  '"watchmakers  de magnetizer"  you  don't have to  worry about too strong a  magnetic field.  the  use of it is a separate subject,  as is  the  deturming if a watch is magnetized.   check out De Carle's book.
Added a 60W bulb standing lamp to the 220V circuit which i was using anyway nest to my bench. Power reduced to around half and now it is heating slow but its effective like before. Tested with a screwdriver magnetized by a neodymium magnet :)
i love the video that you made. it's really the first time i've seen the escape wheel in full arc. is that the typical amout of "swing" that an escape wheel has? i thought that they had an almost full turn, but this one is about 270 degrees or so.
  • 4 months later...
Hi guys, I was just wondering if you could give me your opinion on which demagnetizer to go for. I am a hobbyist and i just service my own watches and any other movements i come across.
The options are all from cousins website and range from £2 to £160.
The cousins cube is £2 will this do the job? I guess you just slide the parts through it and job done?
Etic swiss is £30 and is mains powered.
Greiner and Elma also do demagnetizers around the £160 mark.
So, id really like your opinions, can i do this on the cheap at £2 or is it going to be wise to spend a little more?
You need a mains powered unit to generate an alternating magnetic field to be of any use in watch repair work.
Check out eBay and you will find many Asian versions of the Etic unit (which is almost certainly of Asian origin itself) for anything between £5 and £25. Since all it is is a coil and a switch there is little that can go wrong.
I have two units, an ancient pass through type that came in a job lot of tools and is great, and an Etic type that I paid about £7 for. They work as well as each other.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
