How to remove this stud?
I was going to make my first attempt at static posing on this watch (Vostok cal. 2414) when I discovered this version of the movement has a different stud arm than all other Vostok 24XXs that I've seen, and I've seen quite a few. This watch matters to me so I've been practicing the procedure at least five times on a scrap 2414 where the screw is also friction fitted but with a different construct which can be seen next...
This type of stud arm is also a bit tricky but I've made an eccentric screw to separate the arms to make the stud fall out.
I've tried to push out the stud (first two images) using sturdy tweezers and some force but it won't budge and I'm afraid using too much force and things could go terribly wrong. So, any tips or advice?
There is no threaded holes on this side either? Then it's tapered shape and friction fitted.
If you feel lucky - Kendrick & Davis Inverto Staking Tool is your friend.
But would check the opposite side first to see if it will be safe to apply pressure to reinstall it. Some of these studs have thin walls filled with some sort of epoxy to hold the hairspring.
This is what happens when you get really cheap watches they skip parts. You may find that it's not actually tapered it just Friction in as it's probably really not meant to come apart. But you may still be a little push it out it's probably not tapered either.
The other option would be to unpin the hairspring providing they have a pin?
What would be nice is to have a parts list with pictures but I bet that doesn't exist.
It all depends on how hairspring is attached to the stud and tools at your disposal.
If glued, you might just take a solder gun to the stud and burn the glue.
If pinned !     unpin.
if laser welded remove the stud in a staking set.
You might just remove cock and balance assembly,  place it on a hard surface  ( cock down, balance up) then press on the stud arm to break the stud  loose then push the stud stud out with pair of tweezers, one prong of tweezers under the stud arm, the other on the stud.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
    • unfortunately paying attention to details bumps up the cost. Which is why they shortchange on manufacturing steps if they can.
