Can't get day wheel to sit flat
Lc130
Hi All
I'm a beginner and this is an ETA 2789.  The day wheel looks to be hung up on the day corrector (star looking thing).  It appears to set correctly but also looks to rub against the dial when installed.  What am I doing wrong?  BTW, the not centered day indicator guard around the hour wheel is centered in the other pic.
Thank you
Charlie
IMG_6036.thumb.JPG.a2d4d62347a7c7b24eadc1952e1576af.JPGIMG_6038.thumb.JPG.c433eb419c3f35ec64de51d2b7e61261.JPG
11 minutes ago, Lc130 said:
Hi All
Thank you
Charlie
check this area - it appears to be the issue, unless your above comment is true
Edited by Poljot
That's a recessed guide pin.
I guess you mean the red day jumper.  I do see that it should impact the day indicator.  How do you get it into position?  It needs to be pulled back to take the day indicator.  But how?
The blue jumper spring appears to be in position as the flange at the end of it sits in a hole.  It doesn't appear to be adjustable.
44 minutes ago, watchweasol said:
Hi  usually there is a hole in the day wheel that allows you to hold back the detent  and fit the D/wheel and the detent to seat, does your D/wheel have the hole to allow you to do that.
No hole.  You're right that it's sitting on the jumper.  I tried rotating the day indicator clockwise by hand trying to get the jumper to fall into position.  That didn't work.
3 hours ago, Nucejoe said:
A quick test, remove the said wheel, see if the day wheel falls perfectly in place without it.
It doesn't fall into place but I was able to push it into place.  I tried with said wheel and there's not enough play to move it around.  No hole on the other side to stick something through either.
I did find a video in some simply move the wheel s bit sand it catches.  Here at time 34.  It's not working for me.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
