Is this a front loader?
Lc130
I'm a beginner.  This is a Wyler case 4115E-1162.  There are no indentations on the back nor any tool marks.  Is it a front loader?
If so will Mark's instructions for opening work https://www.youtube.com/watch?v=gGSPqtxqye4.. He pulls on the crown with a pinion remover and uses air pressure to pop the crystal.
There's also this procedure http://blog.watchdoctor.biz/2019/03/23/what-is-a-split-stem/
IMG_5979.thumb.JPG.321051f8f1c4db47176b94a29f10841f.JPGIMG_5981.thumb.JPG.a26ed680a761dfabe4d6b566b456ed59.JPGIMG_5985.thumb.JPG.e9bff36b535d36b02e340a82a802d192.JPGIMG_5986.thumb.JPG.8a298f9b4b4df418b14ea5b29efb069b.JPG
Edited by Lc130
One of the clues here is the engraving on the back perfectly centered and if it was a screw off back they never go back like that. People don't always snap the back so on perfect either.
I always like the caution that there are a feel watches that do not like the split stem separation by pulling them apart. Fortunately probably 90% of them they can be snapped off or out just fine. But there are those tiny percentage where you'll break the split stem
one of the minor things bothering me now looking at the picture it almost looks like that crystal as a tension ring inside? In other words a metal ring inside the crystal which typically you do not find on frontloading watches sort of? Omega will do that but they usually have a ring holding in the crystal assembly. Usually frontloading watches that do not have a holding ring in place expect to build a remove the crystal.
It is a front loader.  I pulled the split stem apart with a pinion puller.  I tried a crystal lift with moderate tightening which wasn't enough.  Should I tighten more or try Mark's syringe method?  I realize this is not a math question and "results may vary".
Thank you
Helpless in Maryland
I'd go for the syringe method first.
If that is so I'd avoid the crystal lift for as long as possible.
I tried a bike tire pump with a ball needle, double poly bag, rubber gasket and my 9 year old putting full weight on the pump with minor leakage.  Won't budge.  I then tried the Bergeon crystal lift at about 80% to 90% full torque.  Still  nothing.  What would a real watchmaker do?
If not running 160 amplitude I'd leave it alone.
Thank you
Charlie
57 minutes ago, fixermole said:
Might that bezel need to be removed first??
Ah Ha!  That's not taught in self learning:) Yes, that did it. I pried the bezel off (now I know what a bezel is) and the crystal and movement popped out.  Thank you...now let's see if I can "service" it without killing it.
Charlie
Thankful in Maryland
Edited by Lc130
Glad I could help. I just happened to work on an old front-loading Bulova a month ago that had enough crud under the bezel and slight pry mark to realize it was removable. Even after 50-100 repairs/restorations, I learn something new with every single piece I work on. Keeps it interesting and keeps my old brain working. Cheers.
I'm not sure the percentage but 90% of the time if the stem is split there is a reason like it comes out to the front
Very common with frontloading watches use theirs of Bezel that has to come off as it's holding the crystal on. Omega does this all the time.
Hopefully a real watchmaker would know what they're doing and take off the bezel. That's another clue when used to the crystal lift and nothing was happening then obviously we were missing something. We really needed a better side view picture to see if there was a bezel or anything like a retaining ring.
I hardly every see the split stems. In this case, the case was very basic - two parts. The entire crown with outer winding step was missing. I purchased a suitable crown and the outer Stem 0.9mm, adjusted the stem length and voila! I've decided not to push it in (what if it breaks! ? ). Instead, I rotated the inner stem and the outer stem up to align "tongue and groove) and simply dropped the movement in. Once it was in, two-part stem was securely locked. Same procedure for removal - no need to pull the crown with pliers, etc. Simply remove the bezel and rotate the crown while lifting the dial until you able to pull it straight up.
As far as I know the only reason you'd ever use a split stem is if the movement is coming out the front. Because otherwise typically there would be no way to remove the stem safely.
Of course this is watch repair there's always exceptions to the rule. Seiko once made a case that they added a separate part to the movement so you can release the stem from the front side once the crystal was removed.  I have a vague memory of seeing a watch that you could remove something from the back to get to the stem release.
Then not all split stem's are separated by pulling really hard. Typically everywhere everyone tells you just pull it out and Most the time people are lucky and it's the kind of split stem that is meant to pop apart. But like the picture above that particular split stem you're supposed to slide the movement out. Mido has a split stem shaped like the picture above and definitely do not want to pop it apart. We went through this Where I work another watchmaker pulled it out damaged it attempted to tighten it and broke it. This required purchasing a used case off of eBay just to get the crown and its stem. Then the movement stem was challenging because it came in a whole bunch a variety of lengths which didn't seem to correspond to the length we had. But eventually we found the right one.
Which is why caution is always required with split stems.
I agree, but slightly disagree. Here is why: some movements could be "front loaders", BUT it doesn't mean there is no access from the back where you could safely disengage the stem from the movement. Which means you do no need a split stem. Timex M107 is one such example - I can open the back cover to visually inspect "what's going on" ? and remove the stem, but I still have to lift the crystal in order to pull the movement out of the case.
In the above example, i did not need to remove the crystal, and the "back cover" was rather a one piece movement holder with a bezel on top. It was rather the case tube design / location that called for a split-stem. Two-part case design Vs three-parts.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
