Identifying clock
MechanicMike
Letter from Joe Collins,
Thanks for inquiring about my mainspring winder. I do not make the Winder any longer. Here are the Plans
I do not supply the sleeves for capturing barreled springs. These can be bought at Merritts Antiques for about $40 US. (9 piece, Ollie Baker type) They can also be found at TimeSavers and other materials outlets.
A video of the winder in use can be found here:
http://www.youtube.com/watch?v=6uOsZ_ZIvLc
Thanks again for the inquiry,
Joe Collins
Email: [email protected]
Update from Al,
Here is a gentleman that built a winder that explains what he chose to do. I do not like his copper clamps for the barrel, they may scratch the barrel. But if lined with leather or made of wood is another way to accomplish the task.
Use a Tap handle which has a 4 jaw chuck to grip the four sided mainspring arbor.
https://www.youtube.com/watch?v=S5XxM5PwSNM&t=149s
And another variation on a theme using mechanics tools.
https://www.youtube.com/watch?v=Qczmx8I1zzI
He also shows the purchased components from stores.
There are many other YouTube video's in case you want to browse other clockmakers solution to a problem.
Clock repair supply houses:
Merritts.com
Timesavers.com
Latest on the 1950 Kundo
Hi everyone-I've wracked my brain and I need assistance. Pretty simple re-assembly you would think but sure enough, the gods of horology want to play games today so it's not cooperating, and after several attempts and looking all over, the center wheel and 3rd wheel seem to be binding up and the whole thing won't fall into place. What am I missing?  The first series of pics shows the train and where the 3rd n 4th wheel are touching, locking up there. Next is the hour wheel, intermediate wheel, washers, lock washer, hand tension washer and hand lock pin, as they sat when I disassembled.  The last 3 pics are time of disassembly, which I'm attempting to do just in reverse order.  My suspicion lies with the washers or maybe a wayward spacer that pinged that I missed? Or a round peg in a square hole? The 400 day bible gives nothing except a nice parts page. I know I bet it's right in front of me but I need a fresh set of eyes. Thanks people I'll check back in awhile. Happy Sunday.
MM
On 1/12/2021 at 5:22 AM, watchweasol said:
Hi Mike  If you can get one of these tools it makes the escapement easier to adjust, nt cheap  the one pictured is from cousins at £27  you can get them cheaper though.
Hi WW I read somewhere that a needle nose pliers does the same. Is that true? Otherwise I have this on my radar
Hi Mike    needle noses will work ok but you don't have the same control, with the tool its micrometer adjustment . If you are going to use needle nose pliers stick somthing over the serrations or file them smooth. Or alternativly make a tool with a slot in it to fit the upper spring block with a longish handle.
As far as the wheels are concerned the center wheel that carries the hour wheel etc will have hole in it for the pin to hold the hands on so put that bit through the front plate first and start from there fitting the other wheels as you go. once the back plate is on check the rotation of the wheels and then fit the anchor/pallet. once done then reassemble the wheels on the front plate
Happy to report, one is on the way. Getting new toys is part of the fun?
9 hours ago, HectorLooi said:
I think you got the 4th wheel upside down. If you look at the original photo you posted, the wheel should be the other way round.
On 1/12/2021 at 6:19 AM, watchweasol said:
IT certainly is  I did in the past use jewelers pliers with fine jaws but the control was not good with this tool you can get micrometer adjustment, would use nothing else to adjust these clocks.
see pics next post.
Hector, Weasol(you mind being called Weasol? always feel weird about that lol)and Hippy:
got back from clearing out the latest snow storm and I took some better pics. I don't think I have the center wheel backwards, as the first pic might be deceiving. it can only go in one way because of the hole for the hand tension washer and pin, and the larger pivot hole size, and the long end to accommodate the hour wheel and cannon pinion, shown with red arrows in 1st 2nd and 3rd pics. 4th pic in red and orange shows where the wheels are impinging on each other and 5th pic shows train arrangement with regard to center/4th wheel and 3rd wheel. so yes, Weasol that's where I originally started was off the hand tension pin hole on center/4th wheel and went from there and ran into the wheels upsetting the apple cart. maybe was this clock assembled wrong by a previous repairman and got the washers wrong or a spacer missing unbeknownst to me? I have zero history on this one only that it's a family heirloom and hasn't worked in over 40 years.
tell you guys one thing-my coloring book and crayon skills are becoming sharp.
266662501_400dayclockhandtensionpinhole.thumb.jpg.74ba65f3e040b5d7bddd1d9657998376.jpg1204405339_400dayclockhourwheelcannonpinion.thumb.jpg.04a0eee0d60ac764aa32d3e38f15118d.jpg525015354_400dayclockcenter4thwheelpivot.thumb.jpg.3972bfec696bbe81bba6f37442b0078e.jpg525015354_400dayclockcenter4thwheelpivot.thumb.jpg.3972bfec696bbe81bba6f37442b0078e.jpg1852516365_400dayclockgeartrainimpingment.thumb.jpg.c4d19c785871cb133435e64bab34b06b.jpg1852516365_400dayclockgeartrainimpingment.thumb.jpg.c4d19c785871cb133435e64bab34b06b.jpg494445512_400dayclocktrainimpingementtopview.thumb.jpg.840999b0d0e1595a592ae19ff84a419c.jpg here I come...
I love this stuff...
post script: the view of the larger pivot, red arrow, is where I suspect a spacer, or the two washers that were directly behind the cannon pinion might go, to provide clearance between the two wheels. but I don't know. anyone want to loan me their 1950 Kundo 400 day clock for a reverse engineering study with me? ??
if you look at your original post, the 3rd photo shows that not all the wheels are clustered against the front plate. One of them is reversed with the wheel against the back plate. As a general rule, the gears are always arranged with the wheel to pinion, wheel to pinion. I think that wheel upside down.
There might be some confusion here. We are not talking about the centre wheel. The going barrel is counted as the 1st wheel or sometimes called the great wheel. So the 4th wheel we are referring to is the one before the centre wheel.
Aha! Ok that might explain it-we were talking about two different things. Counting the barrel. Ok I'll be back at it when I get home later today and let you know. Many thanks Hector.
1 minute ago, watchweasol said:
Hi Mike  I have attached two pics of my Kundo miniture hope they provide enough Information. On way is to look at the wheel and pinion sizes the largest near the barrel and get finer to the escapement, not always fool proof but a good guide.
Combining this with what Hector has said, I  will be checking as soon as I get home later and follow up.  Thanks Weasol.
Bingo! Hector you nailed it! I had gotten so flustered I didn't see it so I went back to the very beginning and looked at the 3rd shot as you said and there it was...well done sir. well done. Thank you very much! if i never get this thing to run again, I'll still be happy I got restored back on track. whew.
yep, Hector and Hippy nailed it, and I confirmed and compared to your pics. Except now, i'm wondering, "How the heck does he get his stuff so clean and shiny?"??
thanks Weasol!
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
