Identifying clock
MechanicMike
Hi all
I was asked if I could repair this clock. I declined because I know nothing about clocks. I don't even know what kind or style this might be. I searched online with no luck. I'm still curious and thought you guys might be able to help. Here's a pic of the makers mark. I should've taken pics of the dial and glass globe it sat under. It's got a weighted, spinning regulator with 4 small globes attached. It's about 10" in height. It has a manual wind in the back.
 Look familiar to anyone? Thanks
Thanks very much guys. I appreciate it. I'm wondering, with my beginner skill set, if I should take it on? I know nothing about clocks, and wonder about parts availability? Hmmm
I'll be passing this info to the owner tho, for sure.
52 minutes ago, watchweasol said:
Beautifull clocks,  as clockboy said got to be spot on..   Kieniger Obergefel  ( Kundo).
No wonder I couldn't find anything on the makers mark-I thought they were a "B" and a "C" instead of a K inside of an O ?
Hi Mike   I think you would be able to do these , Get the book The Horolovar 400 day clock repair Guide,  by Charles Terwilliger as it contains all the essential information regarding these clocks.  The art is the suspension must be good , correct length/strength and set up correctly on the escapement. They are a bit of a devil to set up but rewarding when done.  I have confidence in the fact you would be ok,  there is plenty of help on here if need be.    cheers
greetings WW the more I look into it, the more I'm inclined to dive in. it looks interesting and I like a challenge. Sure enough the first thing I saw was now what I've learned already, is the torsion spring has broken away from the pendulum, and the mainspring was so tight, it's probably set. I released the energy no problem but that's as far as I wanted to go. one good thing-I can see the parts without magnification!? It's in great shape and looks only to be missing a decorative cover on one of the globes. I've already got a phone call into my buddy, whos wife it belongs to. It is an heirloom handed down to her from her grandparents. stay tuned, I'll be back with this one I think. Already looking into the book on Amazon. Used-$49.99 US.
Hi Mike   I have several of these clocks and I love them they are easy to work on good quality. Beware of the pivots as like French clocks they are hard but no worse than the average watch but bigger to see.   The thing is to set them up on the level. The book will show you the back plate, suspension set up regarding the blocks and the fork.  once done a little Windles oil on the pivots and away we go. You will be hooked.  ha  ha.
Hooked is right. All they had to do was show me...there are several editions of the book. Any difference besides cost, between them? It really looks like fun those visible parts are so inviting I can't believe how big the screws are!? The broken torsion spring looks like it could be trouble...parts easy to find or is the usual detective work in order? Yeah I'm already hooked...
Get the 10th edition of the Horolovar book, it's the most up to date version.
The book will tell which suspension spring to get.
ONLY use Horolovar springs, as they are matched to the book recommendations.  Other makes of spring are available, but there is no reliable way of knowing which spring is needed, due to manufacturing differences.
Likewise measuring the old spring for thickness, unless it is known for certain to be Horolovar, is not reliable.
Bod
As said by Bod  the 10th Edition is the latest and with the correct Horolovar spring and set up as per the manual you will be ok. Hope fully the top and bottom blocks and fork are all there if not there seems a ready supply of bits, I guess Timesavers, Jules Borel etc can supply although there are plenty of bits on the Ebay.    Enjiy the experience  and keep us posted.
Bod
Got it.
Will do!
Make sure you have a good mainspring winder so you can remove the mainspring and to reinstall it. I have to disagree with watchweasol on the comment on the pivots of these clocks the hardness is nothing like French clocks, turning a pivot down on a 400 (anniversary clock) is like knife to butter soft.
10 hours ago, watchweasol said:
the pivots are hard like French clocks
Brand new to clocks of any kind and so far haven't seen anything specific about pivots, yet. What should I expect? Do I need to start thinking about machining or polishing?
I didn't even think about that. All the mainspring winders I have are for pocketwatches and wristwatches. I'm betting now there are winders meant just for these? Welp!
There it is again: pivots. Am I going to need special tools?
https://perrinwatchparts.com/collections/clock-bushing-tools
I am myself thinking of buying this 7 PIECE HAND HELD KWM-SIZED BUSHING TOOL SET as the proper tool is very expensive
https://www.ebay.ca/itm/7-PIECE-HAND-HELD-KWM-SIZED-BUSHING-TOOL-SET-for-project/283451935441?hash=item41ff0d4ad1:g:EkoAAOSwY8BbhDju
I'm now seeing two very different clock movements, which will be confusing to some members. Please keep it to the original which was about the 400 day anniversary clock.
Poljot the workings of your clock have nothing to do with the 400 day. What you have posted is a photo of a open spring movement with a strike works and it has lantern pinions.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
