rotary avenger 17 jewel
i recently acquired this rotary to practice on and hopefully improve it.i have cleaned and lubed it and more or less put it back together and it is ticking away nicely although i have not yet put it on the timegrapher .however my problem lies with the date ring and the other components.when i took the guard off (carefully i might add) the spring was just lying about and i have not a clue where it goes.can anybody please help?
Unhelpful answer that spring definitely does not go there. Were missing something which would be helpful for the answer. Then my brain is tired and not glee is the technical term the date jumper thing or the thing that holds the date indicating disc in place notice it's all by itself wears it spring?
The cover plate turn it over and see if there's a recess for the spring to go into. A lot of times the spring will go into that and then when you put the plate down you just move the spring back so it can push on the jumper. Other times you put the jumper under the dates indicator so the spring can push on it when you put the plate down and then gently push it back like was something really fine under the indicating disc and then type in all your screws down before it flies away.
Then if we had a model number for this watch is it might be a tech sheet.
Hi Bernie - you haven't been very generous with giving us a movement ID or photos to help determine that! But those tracks in the date driving wheel? ... could this be a France Ebauches 140-1 C?
There's a good pic at https://17jewels.info/movements/f/fe/fe-140-1c/ which should let you see how that date jumper spring locates in relation to the calendar guard / cover plate and thus pushes on the date jumper part.
Hope this helps.
will have a go at that.it is a FE 140-1C
So nice to have a model number. I snipped out part of the image you'll notice that your cover plate has a nice opening to insert the spring. You can even see a little the outline of the spring in the cover plate. Other than the minor confusion of which direction sometimes to put the spring and it's really nice when I have ones like this.
Hope this helps.
sorry WatchMaker i had posted the mvt info then i saw your post!
15 minutes ago, berniethebolt said:
they never tell you which way the bendy bit on the spring goes!
This is watch repair the word never doesn't always seem to apply.
The reason why never doesn't really apply is that over the years some watch companies have produced really nice service manuals which spell out  everything. Others do  manuals only for unique stuff and in other cases you're lucky if you get a parts list.
This is why it's always important when asking questions to give model numbers not generically say rotary avenger 17 jewel Because yes I searched online and didn't really get very far.
Another thing important to remember digital technology can be your friend like digital cameras  or phones that have digital cameras.  There's a lot of things that you should be using your brain for like why doesn't the watch run  rather than wasting your brain on how to fit parts that you could just taken a picture on.. Is a lot of times I've been very happy if I took a picture of something just because.
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
