My First Cylinder Movement
Deggsie
Hello all, hope you are all keeping well?   Ive just cleaned and reassembled my first cylinder movement, it’s a 1900 (ish) Fontainemelon, 13 Ligne.  Can someone tell me if I should lubricate the escapement teeth please, and what should I use - I was thinking moebius 9145 Grease?  Or should they be Left clean and dry?   Thanks in advanced
Deggsie
On 12/10/2020 at 11:29 PM, nickelsilver said:
Yes lubricate the teeth, normal escapement grease is perfect 9415.
Thank you NickelSilver.   I trust your reply over one other I found, saying use vaseline and fill the hollow of the staff ?
Have a good weekend and Happy Christmas to all.
1 small dot of 9415 applied to every 3rd tooth, installed new main spring, and she started up beautifully.   Did need just a slight swing to get it going after a few clicks, but I understand this is normal as the cylinder escapement design doesn't allow for self start up like the Swiss lever design?  For a 100 year old watch I am just happy to have it ticking again, and not too concerned yet about its time keeping abiity.
Regards
Deggsie
Regards
Deggsie
I suppose the watch case is far from being air-tight. I would try to place as little oil as possible to avoid particles of dust being attracted to the surface of the escape wheel teeth. Otherwise, very soon, your watch will stop or, worse, it will turn into a "grinder" very quickly (depending on usage of course). I agree, would not be concerned about time-keeping ability. No need for the timegrapher :-). Would be nice to see a photo of your 13''' movement.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
