Horologists in Raleigh, NC (or the Triangle)?
Hi all.
The more I've gotten into this little hobby, the more I've realized that hands-on practice is the real way to learn.  And that trying to get help from someone else via the internet or phone is frustrating.
So I'm not advocating get togethers in the middle of a pandemic... but I thought it would be nice to find other folks who would like to learn together (eventually).
There are plenty out there. Check out my videos on YouTube and for sure take Marc’s courses. I have around 30 books on watchmaking covering ‘everything’ and video sets from Tasconi (lathe work) John Trop (Watchmaking and Lathe Work) and I have taken a Marc’s courses. Then I have 7 + years of practice cleaning and repairing pocket watches and watches, with a lot of how-to videos on line.
    • Hi. Thing to do is measure the battery space.  Diameter.  X depth ..    I have seen it listed as  sr626sw.  377 measure to check then check the dimensions of the 377.
    • Hello!  Does anybody have this tool?  This is mine.  If you have one, does it look complete?  How do you use it.  (I have the instruction sheet but it's hard to read!)  thanks!
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
