smooth seiko bezels
yankeedog
Hello all, I have in my possession a Seiko case for an automatic movement. The back is not original to the case. the bezel is missing .  the I.D. and O.D. are 32.10 mm and 35.50 mm  for the groove the bezel would sit in. Could anyone suggest how I might find such a bezel?
if the case back is not original you're definitely going to have a problem. Usually when ordering components for cases for Seiko watches everything is based on the case back number. It could be a different case back as long as it's the right case back for that case then you could use the number. But if it's totally wrong case back here in trouble sort of? If you look at the dial usually on the bottom there is a dial number it's not exactly the same as the case number. But it helps to narrow down the range of what you're looking for.
They is probably I was Seiko is that they've made so many case components. They haven't old it's been discontinued desk of even a bigger problem.  I know their sites out there were people are modifying their Seiko watches if you can find one of those sites may be they of something generic.
That's what I was thinking. There is ALOT of interchange between Seiko cases, things are easy to swap around, too easy ! it does make for efficient manufacturing. The modders out there now seem to be mostly interested in dive watches , in that case bezels abound. This is a standard watch case, probably a Seiko 5 that got cannibalized along the way. I want to make something out of it ! I can find bezels of this type with Seiko part numbers from different vendors. There has to be documentation out there somewhere that can match these numbers to their dimensions, but WHERE ?
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
    • unfortunately paying attention to details bumps up the cost. Which is why they shortchange on manufacturing steps if they can.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  When it comes to tools buy the best you can afford a good set of watch makers screwdrivers if you look after them will last you a life time. I recommend Dumont tweezers Number 3 and number 5 for fine work, you can build up from there. You will need different strength eye glasses. Some now like to work using a microscope. Pliers the box jointed ones are best they don't go out of line.
