Movement Identification - Bovet
mcoulton
Hello
Does someone know what type of movement this is? It can out of a Bovet military watch but I don't think its a Valjoux or a Landeron. I haven't taken the dial off and looked on the other side of the movement.
Thanks in advance for any help that can be provided.
Michael
18 minutes ago, rogart63 said:
But i see a Incabloc spring. So must be shockproof . Never seen a FHF 70 with center second attachment?
 Where?
Many variants to fhf70 with different bridge layout were made, namely inderctly driven min hand, then this with center second cock and your regular sweep second with min wheel incorporated inside ebauche.
Its ancestor fhf30 and on, were mostly sub second versions.
Almost every manufacturer put some versions in their watches,  some were in-house and high grades , Rolex did too.
Thanks to everyone for their responses. You've been a big help. Here are two more pictures of the time piece I'll be servicing. The crystal more than likely will need replacing as will the stem. I can't put any power into the movement as the click won't sweep fully to allow the crown wheel to turn.
Questions:  1.) Does my watch come with a seconds hand? I'm not sure if it does or if it uses a sub seconds which the dial doesn't accommodate.
2.) Are all seconds hands sized the same? I don't mean the length, I mean the pinion that they are secured to on the fourth wheel (?), is it the same for all seconds hands? Hope that makes sense.
3.) I'm thinking of buying an assortment of ETA watch stems, will I find a stem that fits this movement or do I need to search for a fhf70 movement specific stem.
4.) What is the best parts source for this movement; Cousins, Gleaves London?
Michael
There appears to be a seconds hand pinion in the middle of the minute hand hub, and the movement shows a cock and tension spring for a center seconds pinion.
No. You can measure the end of the pinion with a micrometer to determine the correct size.
No. You will need the correct stem for this movement, which may be common to other FHF calibers in the same family, but very unlikely to be common with any ETA stems. If there is enough thread left on the broken stem you could use a stem extender.
Cousins certainly seem to have a comprehensive stock of FHF70 parts.
You may need to get a more positive ID for the movement. Ranfft lists the FHF 70 as a sub-seconds movement but yours has a sweep seconds hand. It is definitely part of the same family as the 70, but some parts will differ from the sub-seconds 70.
Thanks very much for the responses. I believe the next step will be for me to dismantle the movement and have a look. I have a list of items I want to order from Cousin's and if I can figure out what I need from this watch then I'll include them in this order.
Thanks
Hello
I've stripped down this movement and have noted the markings. Can someone please clarify the type of movement based on the photo I provide? Is it a FHF I75 (as is i75) or a l75 (as in L75). I'm also having a little difficulty in figuring out the size for the second hand. I measure the pinion (?) at .30mm (second picture). Does that sound correct?
Thanks
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
