Floating Balance
Willow
Hi after replacing 3 springs on 400 day clock and now have to order 3 more, i thought i will have a go at a HAC small single train clock with floating balance
and wanted to be safe then sorry before i take it apart am i right in thinking that you remove the pin, feed spring through and undo the retaining screws to remove the balance
That doesn't look like a floating balance. It's a pin pivot balance. Yes, you are right. You have to remove the hairspring pin, remove the hairspring from the regulator then loosen the pivot well to remove the balance. Be gentle with the hairspring as it can be damaged very easily.
Do not remove that center wheel there is no need. With that balance (it is not a floating balance) make sure the pivots are nice and pointed, Imagine a pointed pencil that has just been sharpened that is how you want the pivots to look it also will give the balance a good action. If by chance they are blunt you will need a lathe to sharpen them, also check the cups for smoothness in side as well.
Here is a clock movement with a floating fitted balance
thanks oldhippy unfortunately i don't have, or have access to a lathe will check the pivots and hope for the best it's from a HAC single train clock and i bought it because of that type of balance as i have not done one before, thanks for the photo i can see the difference now. One more thing is it ok to put in the cleaner with the pillars and clutch attached
Edited by Willow
added contents
Hi all finally got the hands to move more freely reassembled movement, clock ticking my first balance spring movement can you help me with putting this type of clock in beat how do i know when its in beat, how do i a just it and how does the regulator work it doesn't seem to do anything when i move it left or right. Thanks in advanced.
The impulse pin should be as near center as possible in the pallets, you need it to sound as a nice event tick, in order to get this right you might need to move the balance collect to the left or right to achieve this. If you find that it is way out in time keeping say its gaining a lot and the regulator is unable to  make any difference you need to let the hairspring out the opposite is required if the clock is losing a lot, you then move the balance collect into the center of the pallets. If the collect is tight you might need to remove the collect from the staff in order to get it right. Not all types of these movements will start up automatically when in beat unlike a watch, winding it up gets it going.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
