Demagnetizing a tweezer
Hello dear watchmakers.
I recently bought a Swiss made tweezer in steel and found out that it is magnetized.
Compass is dancing as I put this tweezer near it.
I tried demagnetizing the tweezer with demagnetizer (cheap one from China) but it isn't working.
I usually demagnetize parts using this and worked fine.
This tweezer is not losing is magnetism and I need help.
Any tips would be of great help:)
I don't know about this one you have. I had the same sort but not a Chinese one and it worked fine. Have you followed the instructions on how to use it. You know you can buy  tweezers and screwdrivers that are anti magnetic. There are videos on Youtube about how to use that tool.
These blue boxes usually work fine, if the tweezers are still magnetized try again. Remember to put the tweezers over the tool and hold the red button pressed while you slowly move the tweezers away from the tool, at least one meter. Then you can release the button and test again if it worked.
Donald De Carle in his book advocates wrapping the balance with tissue when de magnetising in order to protect the balance spring, as Quoted in Practical Watch Repairing chapter 21 with practical drawings and how to build your own.
Mine is larger and well tested having used it in excess of 20 years. When build it was tested on various scrap movements to good effect and also tools.  No pictures as it may be again condemed.  I have dismantled some of the foreign Line release/demagnetisers and their quality leaves somthing to be desired as regards the quality of the soldering an wiring. You pay your money and take the chance that you get a good one. or pay through the nose for bergeon.
Using Brass tweezers or tweezers that are non magnetic makes working on watches so much easier. However I have noticed many pro watch makers have tape wrapped around the top of their tweezers which I presume is to either aid grip or to help eliminate static.
On 11/20/2020 at 8:44 PM, oldhippy said:
The main worry about a  demagnetizer is not to have one that is too powerful so it doesn't distort the hairspring.  Always stick to the watch supplies types.
On 11/20/2020 at 8:15 PM, watchweasol said:
I use a large coil driven by a transformer which is a larger scale than the blue box It demagnetises every thing. the tweezers vibrate like a tuning fork in the eddy current. It was made from redundant computer disk drive voice coil and a VDU transformer, a bit of a beast but a worker.
On 11/20/2020 at 6:44 PM, HectorLooi said:
Do you feel the tweezer vibrating slightly when you press the red button? If you don't, the demagnetizer might be defective.
I really appreciate all of your replies!
I tried striking the tweezer with a hammer and tried demagnetizer.
Tweezer lost most of its magnetizm by hammering I think.
Thank you ?
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
