Cousins sell an antistatic bench mat with the label A*F Switzerland. It consists of two layers the upper green and lower white. Between the two is a space that in the sample that I purchased contained some air. If it was made in Switzerland there would be less of a problem, but it was probably made at sea level, perhaps the South China Sea? At our altitude of 720 m it inflated like a flat balloon. The solution was simple, just a hole in the lower white skin. Anyone tempted to buy this 'Swiss' version and living at high altitude, for example Denver, should note this fix. Or try the cheaper Cousins model.
  • 4 weeks later...
I've struggled with this one, the cousins self adhesive ones are hit and miss, sometimes they're okay, but I've effectively had to replace one as soon as it arrived once, the bergeon self adhesive ones are probably one of the the best, but I just can't justify spending that much on a plastic mat. (I mean it really is insanity) The AF Swiss ones, you can't get these as self adhesive, so these have a padding underneath that grips the work bench, but they are a nightmare because they're made poorly (believe it or not) because it's quite literally impossible to get them to sit flat.
Edited by Ishima
You can always go really cheap, a sheet of A3 or A4 paper and replace it every job. The small raised table that sits on top of my workbench was designed to take a sheet of A4 and has worked well for years. White works fine. The only reason I have Bergeon mat fitted on it just now is that I was given it.
Same here. Sheet of paper at first, light green Bergeon mat now.
  • 4 weeks later...
  • 7 months later...
I used to yearn for a black bench mat with side walls but no one makes those anymore. I have been using a cheap mat  but it is too hard and things that bounce and hide do a great job on this mat. I was thinking about the Bergeon 7808 in classic green but now I see so many variations including ridged mats. I don't want an adhesive back since I move from my real bench to the computer bench quite often.
Recommendations?
I recently picked up two of these;
https://www.amazon.com/dp/B011R32JKM/ref=cm_sw_r_awd_H2XUwb3HPC3SH
They are sold as a hi temp silicone baking mat but work quite well as a bench mat. Parts are easy to see and don't roll or bounce away easily. They are available in various sizes and colors for reasonable money. Seem to wipe clean without much trouble, and can be rolled up for storage when not in use. I am very happy with how it has worked for me, but maybe I just don't know any better since I never had a purpose-made bench mat for watch repair.
Edited by steve855
picked up two of these...
I suppose you can always use double sided tape to affix it to the bench/table if it is not staying properly in place...the price can't be beat if it performs well. The different versions from Horotec, Bergeon and Chinese range between US$12 and US$45, the cheaper are either non anti skip or peel the back for permanent (glue) attachment...color will also make the price vary.
    • The problem sounds very much like what might happen when failing to do the reset procedure. The stopwatch not working could be a few things.  There are two different motors, one for the center sweep seconds and one of the minute counter.  Damaging a coil is the most likely thing to do wrong when changing the battery, but that would likely just take out one of the two.  So "start" it wait and see if the minute counter doesn't tick over.  If that ticks, and you've done the reset procedure, it's probably damage to the sweep second coil. If neither works, then it could be the button contact is damaged.  It's a tiny bit of copper trace on the PCB that curls around the edge to make a circuit and it can break off.  There's a way to trigger the buttons from the small pads on the back of the movement, as well as check them with a multimeter, if you are familiar with one. But give this a try, pull the crown out to the second position and hold down button "B" (10 o'clock) for a few seconds.  This is suppose to spin the minute counter to let you reset it to 0.  If it doesn't move and (I assume) button 'A' (2 o'clock) doesn't start the chronograph, then either both buttons have failed at the same time or there is something else wrong. A leaking battery can take out the traces on the circuit board, and this can take out the motors and/or buttons, but you didn't say anything about it and it should be obvious if it leaked enough to do that.
    • Perhaps not where you live, but here in DK, you get by the taxman financially quartered if you order from outside the EUSR. These center wheel weren't that expensive 5 - 7 years ago, around $45-$50. I guess stock is drying up and these days we have to pay with worthless confetti money.
    • A little cleaned up, don't think I will polish the brass. Nice caramel color I think. Looks like the inscription says: Ludwig & Fries Frankfurt A.M.  The lanterns were a little tweeked but able to gently flatten out with no breaks. The 6 and 7 pivot beds are broken but the rest of the beds are intact. Box and velvet a bit rough but still functional. Overall nice and just a bit larger than the one above. Why I need 2 I haven't figured out yet...
    • Good job! Wear it well.. .
