Pocket watch cannon pinion removal
AshF
He all,
I can't remove this cannon pinion using my cheap presto tool.  It's smooth with nothing to grip on to.  I'm reluctant to get my hand removers under the pinion for fear of breaking it.  I guess my only option is to fork out for the Bergeon 4854?  I know it's an investment but it sure is expensive.  Any other ideas?
The other side has this hand setting cap, what's the correct term?  Without removing it I can't remove the bridge.  Does this pop off like a cannon pinion?
I don't normally touch pocket watches, but you know how it goes, friends and family ask so politely if you'd just "have a quick look".
Many thanks, Ash.
23 minutes ago, jdrichard said:
Crap....I forgot that move this weekend
Hah, yeah, I watched your video, then I had the same problem.  I'll try a pin vice later.
Any ideas about the other side?  That setting cap on the centre wheel will stop the wheel from being removed from the bridge.
What does the setting cap look like? Picture
Just had a look. That should come out with the center wheel.
Did you like the video? And, I did complete the job and the little watch is running really well and keeping great time. Just need to install the crystal when it arrives.
You want to give a quick smart tap right on the tip above the canon pinion, where the hand fits. This will knock the center pin through the canon pinion and start it out the back of the center wheel; this is usually enough to loosen the canon pinion and get it off, then the pin is a light friction fit in the center wheel. Usually on a watch like this you can do it without supporting the bridge side, but it's good practice to set it on a bench block or use a staking tool with a hole that will pass the square end of the pin.
As crown setting became more common this old system developed into the modern canon pinion everyone knows, but you will run into this system from the in-between time where there is no square and it's not immediately evident that it's a pin-through-center wheel arrangement. In cases where the center wheel is jeweled, invariably the bridge side of the pin will pass through the jewel, so you can remove the bridge. Do this, then support the center wheel on its pinion before knocking out the pin. The jewel will crack otherwise. Most of the time they are unjeweled though.
Yeah, I love your videos.  I like your narration and sense of humour, always a joy to watch.  Thank you.
Thank you very much guys.  All sorted now.  Once I understood the mechanics of the piece it was more obvious what to do.  I got it on my staking set and tapped it out, it was actually quite easy to move in the end.
A quick follow on question...  Since the centre wheel is friction fit (and doing the job of a cannon pinion) I guess it'll need a little grease right?  Just as you would a cannon pinion?
Thanks again everyone.
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
