Pocket watch cannon pinion removal
AshF
He all,
I can't remove this cannon pinion using my cheap presto tool.  It's smooth with nothing to grip on to.  I'm reluctant to get my hand removers under the pinion for fear of breaking it.  I guess my only option is to fork out for the Bergeon 4854?  I know it's an investment but it sure is expensive.  Any other ideas?
The other side has this hand setting cap, what's the correct term?  Without removing it I can't remove the bridge.  Does this pop off like a cannon pinion?
I don't normally touch pocket watches, but you know how it goes, friends and family ask so politely if you'd just "have a quick look".
Many thanks, Ash.
23 minutes ago, jdrichard said:
Crap....I forgot that move this weekend
Hah, yeah, I watched your video, then I had the same problem.  I'll try a pin vice later.
Any ideas about the other side?  That setting cap on the centre wheel will stop the wheel from being removed from the bridge.
What does the setting cap look like? Picture
Just had a look. That should come out with the center wheel.
Did you like the video? And, I did complete the job and the little watch is running really well and keeping great time. Just need to install the crystal when it arrives.
You want to give a quick smart tap right on the tip above the canon pinion, where the hand fits. This will knock the center pin through the canon pinion and start it out the back of the center wheel; this is usually enough to loosen the canon pinion and get it off, then the pin is a light friction fit in the center wheel. Usually on a watch like this you can do it without supporting the bridge side, but it's good practice to set it on a bench block or use a staking tool with a hole that will pass the square end of the pin.
As crown setting became more common this old system developed into the modern canon pinion everyone knows, but you will run into this system from the in-between time where there is no square and it's not immediately evident that it's a pin-through-center wheel arrangement. In cases where the center wheel is jeweled, invariably the bridge side of the pin will pass through the jewel, so you can remove the bridge. Do this, then support the center wheel on its pinion before knocking out the pin. The jewel will crack otherwise. Most of the time they are unjeweled though.
Yeah, I love your videos.  I like your narration and sense of humour, always a joy to watch.  Thank you.
Thank you very much guys.  All sorted now.  Once I understood the mechanics of the piece it was more obvious what to do.  I got it on my staking set and tapped it out, it was actually quite easy to move in the end.
A quick follow on question...  Since the centre wheel is friction fit (and doing the job of a cannon pinion) I guess it'll need a little grease right?  Just as you would a cannon pinion?
Thanks again everyone.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
