Opening clock mainspring barrel
HectorLooi
After careful consideration, I think solder would not work very well for this repair. The solder joints would be subjected to strain, which caused the barrel to crack in the first place and we know solder joints fail under strain.
I'm thinking of banding the barrel with a steel strap which is placed with some tension. I'm thinking of using a steel zip tie, if there is sufficient space between the barrel and the 2nd wheel.
On 11/25/2020 at 3:16 PM, oldhippy said:
Did the cracks start to open when you installed the spring? if not then it should be OK.
I installed the spring back inside the barrel yesterday and checked it this morning. The copper wire band is still holding.
But now I have a new problem with this clock. The strike mainspring is going to break at the eye. Is it possible to cut off the end and cut a new eye or should the spring be replaced?
Apart from that end if the spring is in good condition you can as you put it cut a new eye.
There is a tool you can buy that will punch a hole in clock mainsprings. I preferred to do it the way my master used to do it. Cut the damaged part off and file it flat and filing rounded corners on the end.   You will need to heat around where the new hole is going to be until it is bright red then quench it in old oil or water. You then punch a few holes in it close together and then with needle files file it out into a shape like a pear so the narrow part fits onto the eye in the barrel. Make sure you file the entire burr away you do not want rough edges rubbing together as this will cause wear.
Thanks OH.
I cut off the end and rounded off the sharp corners, then annealed about an inch of the spring. Then I traced the outline of the hole and used a high speed dental carbide bit to cut out the hole.
This clock seems to have all sorts of hidden faults. I wonder what's next.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.   I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
