Troublesome Chrono Pusher
KOwatch
Looking for next step advice with a chrono pusher. 2.5mm/20tpi pusher sleeve has external splines. Spline tool removed one pusher fine, on the second one the splines are stripped so it can't get a grip. Tried cutting broaches to get a grip from the inside, all these did was widen the hole. So now I've got a 2.3mm hole in a 2.5mm pusher sleeve. The outside end of the pusher sleeve is somewhat recessed, so I can't get a grip with pliers. The pusher sleeve looks brass and the case is stainless steel.
Options include:
Another, larger set of cutting broaches, and then perhaps a tap to clean out the threads. I'm concerned I'll mangle the threads on the case and have to re-tap it larger.
Dissolve the brass inside the stainless steel case? Like the alum-on-steel trick, but with a different solvent for brass-on-stainless.
Suggestions or any other ideas?
Left handed drill bit? Maybe difficult now that you’ve reduced the wall but if you can make it even thinner, you can probably collapse the tube with needle nose or perhaps even some manly tweezers. Then twist it once one wall collapses and it should come right out.
If you want to soak it, PB Blaster works well as a penetrating lubricant.
That’s 0.095”. But you can use a bit larger like 1/8 (0.125”) since the idea is not to drill necessarily; but for it to grab and unscrew.
They can be had (in any size just about) from industrial supply such as McMaster-Carr or MSC. I think I got a cheesy set from Harbor Freight. Those should be good enough.
Success!
Here's my procedure:
spline tool: fail, splines stripped
cutting broach: fail, just widened internal diameter
more penetrating lubricant
several hot & cold cycles (soldering iron & freezer)
cut slot (carefully drilled sideways with 1/32" bit) & 4mm screwdriver FTW
Thanks for all the suggestions! @rodabod, the slot cut was the winning tip (and most accessible without buying more new tools), I was getting ready to try epoxying in a rod or screw as a next step.
The outer spline flange was already in bad shape and I didn't have the 3.5mm thin-blade screwdriver it really required, but I had a cruder 4mm that did the job. Ultimately it made a mess of the  spline flange but still got enough purchase to get the job done. The case may have acquired an extra ding during the process, fortunately it has a lot of pre-existing company.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
