Troublesome Chrono Pusher
KOwatch
Looking for next step advice with a chrono pusher. 2.5mm/20tpi pusher sleeve has external splines. Spline tool removed one pusher fine, on the second one the splines are stripped so it can't get a grip. Tried cutting broaches to get a grip from the inside, all these did was widen the hole. So now I've got a 2.3mm hole in a 2.5mm pusher sleeve. The outside end of the pusher sleeve is somewhat recessed, so I can't get a grip with pliers. The pusher sleeve looks brass and the case is stainless steel.
Options include:
Another, larger set of cutting broaches, and then perhaps a tap to clean out the threads. I'm concerned I'll mangle the threads on the case and have to re-tap it larger.
Dissolve the brass inside the stainless steel case? Like the alum-on-steel trick, but with a different solvent for brass-on-stainless.
Suggestions or any other ideas?
Left handed drill bit? Maybe difficult now that you’ve reduced the wall but if you can make it even thinner, you can probably collapse the tube with needle nose or perhaps even some manly tweezers. Then twist it once one wall collapses and it should come right out.
If you want to soak it, PB Blaster works well as a penetrating lubricant.
That’s 0.095”. But you can use a bit larger like 1/8 (0.125”) since the idea is not to drill necessarily; but for it to grab and unscrew.
They can be had (in any size just about) from industrial supply such as McMaster-Carr or MSC. I think I got a cheesy set from Harbor Freight. Those should be good enough.
Success!
Here's my procedure:
spline tool: fail, splines stripped
cutting broach: fail, just widened internal diameter
more penetrating lubricant
several hot & cold cycles (soldering iron & freezer)
cut slot (carefully drilled sideways with 1/32" bit) & 4mm screwdriver FTW
Thanks for all the suggestions! @rodabod, the slot cut was the winning tip (and most accessible without buying more new tools), I was getting ready to try epoxying in a rod or screw as a next step.
The outer spline flange was already in bad shape and I didn't have the 3.5mm thin-blade screwdriver it really required, but I had a cruder 4mm that did the job. Ultimately it made a mess of the  spline flange but still got enough purchase to get the job done. The case may have acquired an extra ding during the process, fortunately it has a lot of pre-existing company.
    • I found this from a while back CS100 seems fine, but at around 500 Vickers it's not quite as hard as "blue" steel, but still harder than annealed. I'd try to find annealed (the post above has a U.K. supplier of small quantities).
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.  Thanks, Nev. Amplitude v. weak - balance wheel turns over arc of only ~20deg. Don't know how to calculate movement rate or safely vibrate balance spring! Meantime I have reduced the 'dishing' & clock no longer runs for more than a few minutes except face down which supports my theory that it was 'dished' as a hack to avoid doing a proper repair.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
