Hello from Andy
andrewmayer
Hello from Sheffield in the UK. This year I got into automatic watches by modding the Seiko SKX platform. I started by building a brand new Seiko mechanical watch in memory of my Dad using a NH36 movement and parts from various suppliers to achieve the design I wanted:
https://www.instagram.com/p/CAah85-FCka/
I posted the photos on Instagram and people got interested. And so I've built a few other Seiko watches for people and gradually got sucked into trying to fix watches for friends. I'm currently trying to fix a Sellita SW200-1 inside a Bell and Ross which is challenging!
Hello Andy and welcome. I've just joined the site as well. Great looking watch you modded there; well done. I have just started restoring a 4205 Seiko diver. It is a wreck and looks like it has had a leak at some stage so it will be a challenge for a newbie like me. Keep up the great modding.
Welcome also from me a newbie also I lived the watch you built I’m still on the fixing stage of some old manual watches and would ti build one and would like to know more about the process and tools used etc and where and what you bought to make the piece
looks amazing on Instagram very well done
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
