New here
Tuvia
Hi all!
I'm located in NYC and am learning watchmaking. I'm currently an apprentice by an old school watchmaker.
While I'm definitely learning a lot, I believe I am not getting to where I should be. For example; I have no clue what the different watch parts are called even though I work with them on a daily bases.
If anyone can recommend either a book, online course, or maybe even a low paying watchmaker position at a busy location in NY (I can do complete overhauls on simple movements), I would greatly appreciate it.
Otherwise just wish me luck!
Thank you for your introduction and welcome to this friendly forum.
This will help you for the different named parts for a watch. If you are serving an apprenticeship you should ask your master to tell you the parts and what they do. Doesn't he have any books for you to borrow.
1033305402_TZIllustratedGlossary(1).pdf
Thank you for welcoming me and for sharing the attachment!
He doesn't really have books. He earned watchmaking about 70 years ago, whatever names he does know he has a problem translating to English....
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
