Hi from an aging Engineer
Lurch
Good Evening to you all.  As the title implies, I have been an Engineer [Electro-Mechanical] for some time now [40 years] and am rapidly approaching that age where you look forward to new challenges and one of those challenges has manifested itself in the beginnings of an interest in horology.  I am looking forward to having much more time to increase my knowledge of this fascinating subject - hopefully with the assistance of the members of this forum.  Thank you in advance for any assistance I do receive.
Regards, Lurch
Welcome from an 'aged' engineer, that has travelled the same route....(retired 15 years ago after over 40 years in engineering)?. Only been 'playing' with watches for about 6 years now, wish that I'd started it earlier.....?
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
