modalo
gary17
hey guys
anyone know how you get to the motors on a modalo 4 watch winder.
Just got a broken one.
Want to see if i can get new motors or belts for it
The box seems to be in one piece so i presume the revolving bits the watches go in must come out some way.
if anyone knows please share.
cheers
gary
  • 2 months later...
Hi...  did you ever figure this out?   I have a Modalo, lockable 4-watch winder.   It has two big winder circles that hold two watches each.  Pretty standard I think.
I believe the belts have worn out.   I had this challenge a couple of years ago; I sent it back to Modalo; they fixed it and sent it back to me.
This time, I've had Modalo send me two new belts, but I can't figure out how to get into it.  When I look on youtube, it looks like you just twist the part of the winder that holds the watches (just the inside piece) for other winders that look like this.  But this one seems different.     Behind the two winders, it looks like there is a screw (1 behind each)...  but I can't seem to get the big winder wheel (circle) off.
Any thoughts or luck from anyone?
Here are a couple of pics.   Overall unit.
As I said, on most of these, the top wheels (watch holders) come off to reveal a couple of screws.  Typically by holding the black outside and twisting the inside.   I've tried that with as much force as I am comfortable applying.
When I try to look behind the big wheels (see the pic:  I'm pointing with a screw driver) I can see there appears to be a screw behind each one that holds the entire panel in place.  IMG_8120.jpg.7caa38b307ce26a5e4cc917f67457ba3.jpg
Regarding access through the bottom. I did have to that on another winder I had (TimeTutelary), and it was fairly easy to feel the small screw hole through the felt if you paid attention.  I have really checked this one out and didn't feel where any holes would be; pretty sure there aren't.   Where were those on yours?   I will check again.
On 11/4/2020 at 12:59 PM, gary17 said:
hey guys
cheers
gary
Hi Gary - thanks for the reply.   I've just posted a further explanation and a few pics.  Does this look like yours?  Do you have any pics of your winder and how you got in?
Hey
UNPLUG IUT FIRST.
here are a few pics the back door opens and you can the remove the slats of wood.I think the slat nearest the rear should be left to last i think it has electric parts on it. The slats have small screws holding the slats in place in the corners.
The door part (battery compartment)  i removed as it lets you peep in and trace the wires
I put this to one side as i am hectic at the moment.
But please keep me informed as i need two motors my self.
Hope pics help and please contact me if i can be any more help.
I can take more pics if needed
I need to know what motors to buy and how i get them or the belts out
good luck
gary
  • 10 months later...
Hi all
Found this thread while looking to repair my watch winder.
As described, I removed the felt on the base and found the plywood base was glued into the rebate of the boxes sides.
I found my drive belts were broken- probably as a result of ageing.
When I reassembled the box both rotors did not turn. I am suspicious the control board is faulty. Can anyone point me in the direction of where I can find a replacement or give me Modalo's contact details please ?
Thanks
    • Instead of using tweezers, put a piece of rodico onto a toothpick or pegwood. Then set your spring to the rodico, this way the spring is not under any tension when floating it back into the bloc. As you bump into the bloc when trying to find the entrance the rodico will give but still holds onto the spring ie. You wont have the rigidity of tweezers.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
