Omega Seamaster Quartz 1337
SPIGGOTT
Hi,
Just bought this today and the watch is working correctly (time, date).  I can set the hour and date using the crown.
Issue is with the small flush button above the crown used for setting the seconds and minute.  The button seems to depress but nothing happens.
As i say the watch is actually working and the time is correct.  But having to remove the battery to set the seconds and minutes is not ideal.
thanks
 s-l1600bg.thumb.jpg.400c7f64b7890f11d9a67a316de17205.jpgs-l1600.thumb.jpg.d716de848fd495ac5db2e9502e17b86f.jpg
Try fast tapping it. If that advances the seconds hand a bit you know the switch is working but the circuitry that advances the minute hand is buggered.
Otherwise open the back and short circuit the switch with some tweezers for 4 seconds and then let go and press again.
If that fails then you need a circuit board (9600-1337) omega part number.
They are rare as hens teeth.
I bought the last lot on ebay.
Just a thought- is the button OK? It appears set deeply to me. I thought these were just below flush. Perhaps it is making contact all the time?
Im also guessing there is an oring in there. Was that replaced?
Maybe take the movement out of the case and see if it performs properly.
Ok.  The plot thickens....
Went to change the crystal out today and while doing so i decided to take a look at the push button and contacts.
It appears that the previous owner got a bit heavy handed with the button and has bent the lever behind that touches the contact.   attached photos.
So bypassed this and touched the contact directly.  No issues with the circuit board as all works as it should.
Question i have is regarding the push button.  as you can see from the pictures when i removed it from the case it was covered in a black sticky tar like substance.  not sure if this was the gasket that had just broken down or someone used some sort of glue.
What should be here, also once pressed what causes the button to come back out.  see no spring???
That WAS an o-ring and it may rely on the lever on the movement to push it back out.
The stuck o-ring probably caused the excess force used. The lever will have to be straightened or replaced as well.
See if you can find the tech sheet on the case by case reference number, which will have the exploded view of the case assembly. (Plus part numbers)
Hi, didnt require any parts.   The lever was not bent it had hopped over the front rim (a raised edge to keep it inside movement perimeter).  Once i removed it and reseated it was fine.  small tweek with pliers and all good.
Bought a full box of assorted o-rings a few days ago, so when they come in i will fit to pusher and replace.
the one job i started out doing (replacing glass) didn't happen as i ordered the wrong size.....
thanks for advice.
    • Hi. Breaks like this can br fixed with conductive paint like the paint used to repair a car  rear screen heater. I have used it successfully, you don’t need much and unlike solder there is no heat 6020A-1.pdf
    • the problem with vintage watches and yes quartz watches can be vintage is availability of parts will be a problem. I have a link below where we can cross reference the coil and  I was hoping for more. Another problem for vintage parts are everyone on the group gets used to ordering from online. Conceivably the physical material houses that still exist out there might have the part and you'd have to reach out to them and see if anyone has one. this is because they don't list every single part that they have online with the exception of cousins where everything they do is online work just doesn't exist but the other material houses can have stuff not listed. Otherwise just set up a search on eBay and sooner or later it will possibly show up if you're lucky.   http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK_6020A
    • Hi welcome to the forum.    Enjoy
    • the bestfit book refers to Revue as wittnauer and the fingerprint we have this.
    • Maybe a little off-topic, but it still amazes me that most people (and myself before I got into this hobby) don't realise that the movement of their watch was (in most cases) not made by the name on the dial of the watch. This is especially true of many 'fashion' watches which use the cheapest of cheap movements ($4 each) which are completely out of proportion to the overall cost of the watch ($++100s). Usually the actual manufacturer is stamped somewhere inconspicuous on the movement, usually around the balance, and this is what you need to find so you can locate spare parts or servicing manuals etc. This is like buying a top of the line Rolls Royce Phantom and learning it has a BMW engine..... oh wait a minute, it does! (6.75-liter, 460-horsepower BMW V12 engine - reference)
