Thoughts on painting hands
The hands on my daily wear watch are highly polished in such a way that they're highly difficult to see at most angles. For some reason, the manufacturer also neglected to fully lume the hands for other unknown reasons. Clicking through the embedded link back there, you can see that they also went with a yellow/orange (imitation faux antique). I don't particularly care for the faux antique look, but I think they did a really bad job in a good way. It adds color. To fix the visibility of the polished hands and continue the colorful theme, I thought it would be great to get a set of blued pilot hands. The iron oxide is less reflective without being dark, and obviously colorful. I thought this would be easy since it's a 2824. Unfortunately, it looks like watch hands are also subject to an eta style lockdown pretty much everywhere... You can get all manner of generic hands, but the selection is poor and less than exciting. Decent looking pilot hands in appropriate lengths for 2824s are employed by a billion different manufacturers, but I have yet to find one willing to part with a set that don't have a watch attached. Finally, the unusual nature of the dual rotating registers relative to the core time keeping sections of the dial mean I'm dealing with some odd hand lengths.
It dawned on me that most of the blue hands are painted, not blued. I don't know what material the existing hands are, but I doubt they're steel. They don't need any polishing or anything though, so maybe it would be easy to paint them? I could also fix the missing lume at the same time. Does anyone have any ideas for how this would be done? I'd also take recommendations for sources for hands, but I've pretty much given up on that idea. Thanks!
Try a gun bluing kit.
The hands are most likely stainless. Remove the lume and clean surgically clean. Then follow instructions on the bluing kit. Birchwood-Casey is a brand that jumps to mind but I’ve no idea if they’re the best.
Also bear in mind some of the bluing kits do a blue-black (midnight blue) which may not suit your style. Test on some junk hands first!
I have a bottle of chemical bluing solution somewhere, but it's definitely the blacker variety. I hadn't considered that the hands might be stainless; I assumed (based on nothing at all now that I think about it) they were plated brass. Is there a way to tell for sure?
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
