Starting with my largest (wrist) watch.
Tudor
This, is one of my favorites. I clearly remember when I first saw it: I used to work on Long Island and come back to Connecticut each weekend. I saw it on a billboard north of the city, on 95. The new Omega Seamaster Planet Ocean.
I wasn’t crazy about the name, but coming off the Pierce Brosnan bond watch this was (and is!) stellar. Note I liked the blue bond watch before the turn of the century, and I had a white faced GMT during that era (because I saw so many blue ones). I miss that watch sometimes but legibility wasn’t the best actually.
Fast forward a couple years and I’m at the maul with a couple good friends and I decide to pop into an Omega jeweler there. They had a pre owned all black 45.5mm planet ocean on the bracelet. I wanted the “big” one, and still enjoy it, but I think a 42mm version would be even more perfect. I had a rubber strap put on because it just plain looks better that way.
The Orange version shown on that billboard looked awesome at the time, but I thought it would fall out of fashion in time, and it has, as far as I’m concerned.
Mine is the first generation. Aluminum bezel inset and painted numerals. The omega logo is applied, like the vintage dials. I appreciate that detail. The newer ceramic bezels and applied numerals are arguably better, but not to me.
This has been back to Omega once in the ten or more years I’ve owned it. NJ service center did a fantastic job, and only replaced what I authorized. Light touch up on the case and it’s been perfect ever since.
Thank you Joe.
I believe all the co-axial movements are chronometer grade. Certainly capable of it
I had bought (and later re-sold)  a water-logged 2500 years ago to learn about. Very similar to the 2892 it is based on, so one in need of service might be a good avenue for you.
  • 3 months later...
That is my favorite iteration of the Planet Ocean, though in the midsized case. I agree that the blue Pierce Brosnan watch is nice, I think I would not be able to get to reading those hands. The 42mm of your watch with the 2500D movement is a bit of a grail watch for me. Very nice and thanks for the post.
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
