cyma = eta
gary17
Hey guys
I am working on a cyma the only markings on the movement cyma R.408.00.
Which is not in cousins or ranfft. So looked around and most people seem to think its a ETA 2722R,2724R or 2728R any way i need a mainspring and they dont make em any more so got measurements of ranfft 1.25x11x0.125 i put these in and it says there is none. It also wants length which i do not know. So what i am asking is what number is it best to fiddle around with so i can get a nearly correct mainspring. Its a nice watch so worth the effort. Its a auto as well.
cheers
gary
Take out the mainspring and measure the length.
Go closest shorter mainspring. Shorter, you'll loose  some power reserve but otherwise should be fine.
There are calculations to determine how long based on the area of barrel (see NAWCC website). Input the the ID of the barrel, the OD of the mainspring arbor, and the thickness of the spring. The idea is you fill a certain amount (about 1/2?) of the barrel area with coiled spring, with room for the spring to hold tension.
Altering the thickness will change the torque available; increase, you can add too much and overbank, decrease thickness and you have too low amplitude. If it's a really old watch (not yours) you have to consider this, as older spring material was less powerful for the same thickness. I've read that watches with bad amplitude (or too much) after servicing can benefit from a different thickness, not a common case.
Last resort, you could go for a smaller width, the spring would fit looser in the barrel but one size lower shouldn't really make too much of a difference (so I hear), although technically you want to re-size up the thickness in that case, and there's calculations for that.
The last value you'll see on the cousins website is the size of the mainspring package, which should be equal or closest smaller size to the ID of the barrel.
If you look at some similar ETA models you might get an idea of approximately how long the spring is, often it's listed with ranfft. Unfortunately for you, not for 272x series, nor the 26xx series, but there is for the 25xxs, and the 277x, so you might have some starting points there if the springs are the same for the other dimensions, barrel size, complications and rate.
If you can find your mainspring size measurements, there's other styles of model numbers like the bestfit catalog number (usually a number and a letter), and if you know these you can often find NOS "white-a-loy" springs on ebay or elsewhere. There's scanned documents online from Marshal Handy, Bestfit, General Resorts, Nivaflex that will list more specs on your movement and mainspring.
Like here:
https://watchguy.co.uk/cgi-bin/mainsprings
Some conflicting numbers in multiple entries for the eta2722, but you're seeing ETA2722 numbers similar to the ranfft data, with a length less between 360 and 400mm. Also seems to suggests your GR reference is this one available from cousins:
1.25 x .135 x 400 x 11 Automatic
GR3150X
Which at .135 is thicker than Ranfft's listed .125 (could be an error with Ranfft?), so you'll have to resolve that discrepancy with some more data points. Best to measure what's in there and/or look it up your movement in some more of those catalogues.
Good luck
Edited by KOwatch
No mainspring? Like the barrel was empty? You can double-check the barrel ID to confirm it's 11mm ID.
The generale resorts catalog (you can download sectons from cousins) seems to think it's the GR3150X. I'd start with that one.
The other bestfit catalogue I'm looking at only goes up to the 25xx series.
There's the older Dennison system of mainsprings numbers, for some watches it's useful to look for those on ebay or somewhere, I think in your case it would be a 39T or a 38T, that's a width 3, thickness 9, length T corresponding to a 1.2 x .13 x 393 mainspring, they go up in whole sizes so it doesn't correspond exactly. There's a 38T in the Cas-Ker catalog, I think I'd stick with the GR mainsprings though.
40 minutes ago, AshF said:
Sorry to hijack this thread.  I've got an old project CYMA R.421 that I've been trying to find a part for for a few months.  Perhaps this is based on an ETA?  Where is a good place to find out?
Have you checked www.julesborel website, lists many tavaness 420 parts in stock.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
