New member, old man
ricardoch
Hello,
First excuse if any unconvenience, English isn't among my best skills.
I fall in love with watches (and clocks) as a child, I break my first "Cauny" watch around 7. I persisted and was able to repair some from fool family member watches. Work keep me away from hobby long time, although I was able to join several cases, watches and parts that today I try to revive in my 60's, with a pair of shaky hands and poor eyesight.
I have a few tools and little knowledge, but found that your're an inveluable resource to fill my infinite gaps, I'll try to not bother you too much asking for help to do things the right way and not only my fool solutions.
Most watches I'm fiddling today are discarded 10xx and f300 omegas and some automatic ETA's, some survived me, some not so much.
I thank you all for sharing your valuable advice and knowledge.
Kindest regards from Spain.
Hi, and thanks for the greetings,
I have some accutrons as well, I discovered through the expensive path that you could destroy a tuning fork watch if you dare to more than watching it, although I was able to revive some thanks to old stock bought years ago, but quite expensive in today's market.
I promise that I will never touch an accutron further than hands, dial or keyless, but was able to repair and adjust some ESA and Omegas. those movements are far easier than bulovas, even with my hands and a microscope.
Not dealing with tasks as I only dream with better tools, but keen to learn and share if I can help in any way.
Again thanks for the welcome post.
Ricardo
Hi and thanks to all,
f300 are (IMHO) the "easiest" to fiddle among the tuning fork watches, they are built into two different modules one for the fork itself with the index wheel and the other for the watch itself, but any case really tricky even with a good microscope and firm hands (no my case)
I dared to touch some, incredibly easy to break or unset the fingers and very delicate to adjust, but never tried even to touch any accutron (the original and first diapason watch))
I hope to learn a lot from your awesome knowledge and ideas, and share some of my projects, usually very simple ones, as my hands and eyesight aren't what they used to be.
Again thank you all for your warm welcome.
Ricardo
  • 4 months later...
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
