Repair: not a watch.
A few nights ago, as I was finalizing a project at 1:30 in the morning, the hard drive died.
So, I had to replace it. I had ISO discs for various software version, so it wasn’t too bad. (Last picture is back in the rig).
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
