Introduction
mmg
Hello everyone,
   I started collecting watches a few years ago and have decided I would like to be able to look after them myself and so begins my journey into watch repair and maintenance. At the moment I have gone through some of the course and am gathering the tools needed. I have started to tinker with some old quartz watches while I work up the courage to actually try to take apart a mechanical watch and put it together again. I've bought a job lot of old watches and have selected one to begin practicing on. It appears to be a clone of a Tag Heur  Carrera and I've run into a  problem. There  doesnt appear to be a way to release the crown from the case that I can see. I've loosened any screws which are visible but the crown remains firmly in place. Any suggestions or hints would be appreciated.
Thanks in advance
mmg
  • 4 months later...
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
