Omega 1022 - runs fast
Khan
Hi
Despite serviced at prof watchmaker, it runs half an hour too fast per day, even if its demagnetised. I have tried re-clean the balance and regulating the watch but no luck. There is a noise coming from the balance spring when running, as if the spring is sticking to something. But the spring seem flat from section view and intact.
  Hi Khan,   Coil looks too close to stud so it can hit the stud upon expansion, judging by the picture, the free section of terminal curve( between regulator arm and stud)  is too close to coil too.
Center the coil.
Center the coil.
Are you sure the stud is seated correctly? It looks like it might be pointing inwards, which would cause the coil to be too close to the stud.
In light of mikepilks point, the noise is possibly from loose stud, in which case it should sound unfamiliar and unlike anything you or your tg has heard before.
Make sure stud screw is tight on stud, before you manipulate the end curve, loose stud might also explain why the end curve is unparallel with other circles of the coil.
A side view close up of the coil helps, it seems like end curve is unlevel with the coil.
Out of curiosity did the professional watchmaker return the watch running 30 minutes a day fast?
Was there a reason for cleaning the balance wheel? Did it look like it was having a problem? Then I don't suppose you have a timing machine? Even though if you're running that fast the typical timing machine is not going to work.
It would've been nice to have one more picture Of the watch without the balance wheel in the watch. Another source of noise problems could be the screws holding the pallet fork bridge in place.
Then thank you for the pictures you didn't give us as they reveal something interesting. Did you notice the roller jewel it is in alignment with the balance arms? That makes it insanely easy to put this watch in beat. If the first picture is the balance wheel of no power the arm of the balance wheel should be over the pallet fork jewel and it's not by quite a bit.
Then as pointed out by rodabod It's usually best to look at the balance wheel in the watch as that is usually where the problem is.
It might be a trick of the camera shot but these coils look very close to each other. It only needs one coil to stick / touch another coil and it will run fast. It could be magnetised. Also as J has said was it OK when it was returned.
Hi
Thanks for all the generous responses. The watch was serviced a couple of years ago and has been sitting in a box since. Haven't worn it after service, unfortunately. I don't have a timegrapher, I use an android app called "clock tuner", works good enough mostly. It runs half to one hour fast by checking in it a day. It was running 5 min fast prior to service as well. I re-cleaned the balance because the coils were sticking in all the circles, also after demagnetizing it. But it still sticks occasionally in the outer coil. I hope there is another solution than spring manipulation in this case.
You definitely need one to work on movements, much more than an expensive balance tack, which main function is to distort the hairspring.
There are parameter and visual information as discussed here so many times, than no application based on the embedded microphone will ever show.
Always happy to see somebody who agrees with me that balance tack is the work of the devil. Okay when you're in school and make one a nice training exercise for using the lathe but not good for hanging the balance wheel. At least in my personal experience.
This is my complaint of the problem isn't outside of the watch the problems in the watch. Pictures of the balance wheel outside of the watch can give bad impressions. Bad impressions lead to bad diagnostics like based on the pictures outside of the watch I would get a balance complete. Versus pictures inside the watch where it doesn't look that bad.
From your experience it works okay mostly. The problem is from our experience it doesn't work very well at all and leads to bad diagnostics and wasted time for all of us.
What did you clean the balance with and was it attached the bridge at the time?
Can I assume that when I came back from servicing that it was keeping time?
I don't suppose you could record the noise for us?
"clock tuner"
When you use your app what does it say is going on maybe post a picture.
Were still stuck with a minor problem of what was the watch doing after it was serviced? Let's make the wild assumption that it was probably fine. What did you clean the coils with as maybe didn't do a very good job. I would resist bending the hairspring to fix a real or imaginary problem until we really know what the problem is. Because if the watch was running fine after servicing unless you bent the hairspring taking it out or hanging it on the balance tack then the hairspring should still be fine.
Hi
Thanks for reminding me purchasing a timegrapher. I realize the practicality of it afterall. Principally, I remove the cap jewel and clean the balance without removing it from the balance cock, in petroleum. The watch ran very bad, first time I used the watch, witch was very recently.
Hi
I figured it out by manipulating with spacing around 2 o'clock on first image. 2nd and third image are after manipulation. There is no more musical sound of coils scratching each other and keeping since 3 hours and hoping for the best. Thanks again for all the input, really appreciate the helpfulness here.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
