Deteriorating lume on a vintage watch
Rafael
Hi all,
Any advice on how to stop an existing vintage lume (70' Rolex sumbamariner) from detirorating? Can a clear nail polish applied at the back of the hand will help? Is it a good practice?
Thanks!
Edited by Rafael
Hi   If you are trying to preserve the origional lume I guess it would work, but that depends on how bad the lume is. Apart from re luming the hands anything else is just patching up.  There are several video's on how to re lume  and are worth watching.          cheers
Thanks watchweasol. I can re-lume the hands and i'm still considering this option but i'm not sure this would be the best alternative here. There's a nice charm in the vintage lume. Except for the minute hand that I mistakenly deteriorated in part, it's in good condition (but not luming of course). I just don't want that the rest will crumble too if I decide not to re-lume.
Just now, markr said:
If it was mine I would leave the original lume mix some lume to match the old and only fill in the missing lume on the minute hand then some clear on the back to try to stabilize the old lume.
I think that this is the direction i'm going for since the damage annoys me as well. Still need to know if the nail polish trick will work.
The problem with “patching” is that the color of the new stuff is fixed and the original lume color will change over time. My blue dial 9411 was quite dark but exposure to sunlight has brightened it up.
So, no matter how perfect the match is now, in six months it’ll look very obvious it was repaired.
Both my 1680 and 5512 have list their lume in the seconds hand. And my Tudors are probably going to crumble any second. I don’t know if clear nail polish is the right material to use, but stabilizing from the back side is a good idea. I was considering water thin super glue but thus might penetrate too deeply and alter the lume. I think you want it to penetrate, but not so deep it is apparent on the top side
I haven’t done anything but I know I need to do something.
I would be very cautious using any CA type glue inside a watch, least of all anywhere near a dial. As I understand it the potential for discolouration (particularly of the dial) as a result of the outgassing products of CA glue is too high a risk.
I have used thinned down acrylic lacquer to stabilise flaky lume before without issue.
Yes, I understand the pitfalls with these adhesives, and would dry the hands for a week prior to instalation if I went this route.
Basically, any evaporative cure agent (such as a lacquer or enamel like nail polish, or any air-cure adhesive) will have outgassing, and none of that is good inside a waterproof watch case. It's an important point you bring up, and good for those not aware of this to think about for sure.
An epoxy, which is chemically cured (or catalyzed acrylic urethane), might be the right answer. But it must be very thin, and fully cured prior to installation. I always double the "stated" fully cured times to ensure it's done. And of course the "sniff test" to see if I can smell it at all. If I can smell it, it's still curing, and will wait longer before use.
But it's a great point for those not used to working with adhesives and finishes.
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
