This, Just in! (Staking and jeweling set)
In terms of punch width/tolerance, what’s important to me is that the punches can grip the tool hole well enough such that they don’t drop and can smoothly be adjusted in height (especially when the punch is going onto a balance wheel).
12 hours ago, Rocket said:
I have a Simonet 450 lathe. Its a bit of work to do on it. But it works. Though, unfortunately missing the milling and grinding equipment. And some W20 collets. And yes. Not only strange pitch threads on them. They are expensive as they were made I gold. Nice quality though!  Bit big for watch work I want to learn about. So also looking for a 6 or 8mm collet lathe. Dream would be a F3 mill to play with too. Hopefully in the future. ?
I had a Simonet 450 for a while but sold it on before ever really running it. Very very nice machines. Milling and grinding attachments for Schaublin 102 should work fine. W20 collets are quite plentiful secondhand and sell for far less than the W12, which so many Schaublin 70 owners are constantly looking for.
I have a Schaublin 102, which is the same center height as the Simonet 450. I find that with that and my 8mm (50mm center height) lathe I can cover everything I've needed to do, the perfect combination. I had a 70 for a short while and sold it on, just a little too big for small work and a little too small for bigger work, haha.
Not wanting to interrupt the staking thread. But a 8mm with crosslide would be nice. Maby grinding tools. But we well c what one can find. ?
Some further info on this thread.
I found a seller on eBay with NOS Marshall staking stakes and stumps. (eBay seller btlgrd - he also has a fair bit of Levin lathe parts) I will be ordering the one broken one, as well as a couple sizes that were not included with my set when sold new- I will then have every stake and stump Marshall made (and probably use 1/10th of them in my lifetime...)
I am attaching a couple pages that those with Marshall sets may find useful when searching for stakes and stumps. Note that Marshall did not mark their stumps, and measuring is the only way to identify them. Also, stakes are identified OPPOSITE they way they are shown in the paperwork- so a L7 stake (the one that I have broken) is physically marked on the stake as 7L. This is important if you are hunting, and the seller may not know this...
I also found a closed eBay listing which included some K&D stakes along with the Marshall set- sizes are "in between" the Marshall sizes, and I added that note below as well. Good info for those needing a slightly different size.
I finally, today, got around to placing the order. Seller combined shipping for me, so I only paid that once.
Smooth transaction so far, and these stakes are brand new, still in cosmoline! Grab them if you need them!
He could probably make a full set for you; but at $4 each, that could get pricey... He may do a special deal on a full set as well. Worth asking, if you have a nice tool with rusted, nasty stakes.
  • 4 weeks later...
I missed this whole thread...
But anyway, I too have a Marshall set and have purchased from this seller. His stock is stunning. I've never asked where he got it all but it sure is fun to look at. Still packed in cosmoline and wrapped in wax paper, in original crates.
Love my set btw.
Yes, mine were well coated but cleaned up perfectly. I have every available stake with none broken (yet).
if I could get that incabloc spring done I’d feel better about it but there is no way you are doing something like that without this tool.
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
