Glass blew out during water resistance test
AP1875
Your case is leaky. When you pressurised the tester with the watch inside, air was forced into the case, euqualising the pressure inside and outside the case. When you released the pressure in the tester the higer pressure in the case popped the crystal off.
If you had released the air slowly with the watch submerged you would have seen a stream of bubbles which would have shown you where the leak was.
To fit the glass back in, do I need to remove the rotating bezel, put the plastic ring on the glass and then push the bezel on top of the glass?
Some videos of watches with rotating bezels have the bezel installed and then the glass is pressed in after.
I'm not sure which method applies?
It depends on the particular watch. If the bezel does not get in the way of working on the crystal there is no reason to remove it.
Re refitting:
It depends on the design of the rehaut and the crystal. Some rehauts have an undercut on the OD and the crystal (should) have a corresponding protrusion that "locks" into that undercut.
But, since it blew off, it is quite possible the "lock" is not there.
All that said, I personally would disassemble the crystal retainer and bezel from the crystal, install the crystal with a schmear of G-S, and then press the retainer on (then the rest of the bezel assembly).
If this is a "click" type bezel, it needs to be completely disassembled before being put back on. If it's a bi-directional one, you can "get away" with not taking it apart, but it is best to do it in pieces to be sure each piece seats correctly.
Some crystal retainers have an o-ring groove on their underside too. Make sure the o-ring is there, and that it is lubed with Molykote 111 prior to assembly. This does not stop leaks, but reduces case corrosion.
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
