First clock movement try...
bsoderling
I have always liked the looks of the typical 50 to 60´s kitchen clocks and when I recently stumbled over one dirt cheap, I couldn’t restrain myself.
with no prior expeience from clock movements, only watches, I wanted some advice on how to proceed.
I suppose the movement is as simple as they come in this area? Any ideas about manufacturer?
The obvious fault found is a broken click. As I’m somewhat hesitant to start ripping the thing apart, my thought was to drill out the rivet and hopefully be able to use a replacement from Cousins (they sell ”assortments” that may do the trick). Rather than riveting, which I suppose will be tough with the movement still assembled, my thought was to simply use a screw and nut to fix the new click. There should be space enough to get a screw in there...
Another thing I noted was that the pallet (correct name?) sits tilted between the top and bottom plates (photo attached). One side of the mounting has wide holes supposedly to allow some adjustment of the locking action. But here it looks like a lot and the marks around the screw heads seem to indicate that there was a previous lower mounting. Any thoughts on this would be appreciated.
I ended up making a replacement click from a piece of steel plate I had laying around. By no means an identical replica but it does the trick.
used the old rivet and made some indents in the surrounding brass plate to squeeze it tight against the rivet that was really hard and wouldn’t deform with my stakes.
so far the click holds and the movement with its pendulum ticks nicely. Keeps reasonable time and can probably be tuned a bit with the pendulum adjustment screw.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
