I’m new and love watches + Help please ?
SiSays
Hello my wonderful watch people.
Like many of you I am a real watch lover, this began about 3 years ago and I have purchased many, many watches in this time...
However, I have encountered a problem ☹️
I have attempted to change a capacitor in my Seiko Kinetic watch, managed to get everything out thanks to the ‘watch repair channel’ but having got the new capacitor installed I have lost the tiny screws required to put the plate above the capacitor back and then the rotor.
Any help would be greatly appreciated as I am lost for ideas and have been to multiple jewellers etc with no luck..
Thank you
Get a small neodinium magnet and wrap it in white painters tape. The tape only serves to make dark objects stand out against the light background, so it is optional.
Remove any other watches from the area you were working in so you don't affect them with the magnet,  and carefully and methodically  sweep the bench, carpet, your trousers, socks, jumper floor, and everything within a few feet of your work area. Hopefully the tiny screw will stick to the magnet and you will see it sitting smugly on the white tape.
I have lost count of the number of times I've had to endure this little ritual, looking for tiny springs, screws, watch hands, winders and all the other little parts that like to mysteriously vanish from the end of my tweezers. I recently found a spring from a Sekonda that I lost a few weeks back, while looking for a screw that I had just dropped. I also found the screw ?
Brass and stainless steel parts are more tricky as they wont stick to the magnet. For those, I attack the carpet with a piece of duck tape, in the hope that I'll pick up more parts than carpet fluff.
Edited by AndyHull
Thank you so much for your responses everyone ? I need 2 small screws to hold the capacitor bracket on and a slightly bigger one for the rotor.
I’m at work at the minute but can uploads pictures this afternoon if that would help.
I am in the UK, namely London and May need to get someone to fit it for me if I can’t. Am happy to pay..
4 hours ago, philipk5 said:
Same two capacitor small screws as in pc21 etc movement. Are you in the UK ?
7 hours ago, Watchtime said:
If you can send me the caliber I am happy to check if I have it in my parts drawer
Please find a picture attached... as I say, any help would be greatly appreciated...
Do you have any broken/non working scrap ordinary quartz Hattori movements such as the PC21 ? If so use the the small screws that hold the coil etc in place. As far as the rotor holding screw as suggested invest in a magnet and scour thoroughly the general area it went missing. Missing small parts do seem to reappear given time to drop out of orbit!
Good luck.
The screw screws into the centre of the bearing so the only danger of overtightening is to break the screw!
It should be tight enough to stay put but not so tight that it breaks (obvious but completely useless advice!!!)
Glad to have helped.
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
    • Haha. You're just in a wicked mood today John 😅
