  • 0
Clean without a machine?!
Hutchlee
 Share
Question
8 answers to this question
  • 0
Very often asked question -  fully answered in the pinned topic
However, to return some brightness you need an horological ammonia based solution.
Rinse with petroleum ether (aka benzine, which is NOT benzene). Do not use lighter fluid as you will spend more per liter, and it's made to burn not to clean.
  • 0
It is perfectly safe to use Ronsonol lighter fluid; I used it all the time for the balance and pallets for all watches. It is also shellac friendly. You will need a small container with a screw top as it evaporates very quickly. Expensive if you use it for complete movement cleaning. Some on here use those cheap ultrasonic cleaners you can get from ebay.
  • 0
I didn't said that isn't safe; I said that's more expensive, and not an horological product as it not purified enough. It is not recommended by any maker or book, they all mention benzine.
Above from a 1904 book, much truth in the statements above ?
  • 0
I clean and rinse ( hairsprings/balance completes)  fork/pallets and escape wheel in lighter fluid and clean other parts in avgas( aviation gas) cuz its cheaper. You might use naphta instead.
Of the parts you show, you can soak balance+cock, fork and escape wheel in lighter fluid, balance+ cock seperate from the other two. I soak the rest in coca-cola over 24 to 48 hrs , brush with a tooth brush use powdered detergent as abrasive/cleaner, keep brushing under tap water as a rinse. The better you use the powder as abrasive the shinnker parts get.
Haven't yet been able to source petrolium ether to try.
Pin pallets break/ bend easily, handle it as you do hairspring.
  • 0
For a budget watch such as that one, I think a soak in lighter fluid (and pegging the holes) is a reasonable suggestion.
Alternatively, another budget suggestion is to use Cillit Bang degreaser (yes, I can’t believe I just suggested that either) which also brightens metal. I have used that in a pinch for bare brass clock parts before.
  • 0
I don't advice to use any old cleaning agent. These modern cleaners off the shelf who knows what damage they can do. Never ever use anything like Cillet Bang on antique clocks (antique) I mean any thing from the first decade of the 20th century. Heaven knows what it can do to brass and steel. You might think it looks nice to have a bright shining movement but that doesn't make it go.
 Share
  • Similar Content
    • By Salvatore
      Here is a parts cleaning machine I put together for $10.
      The oatmeal carton and coffee cup keep the parts away from the magnet so that no parts get magnetized.
      Gangster rap is great for super filthy vintage watches, or AC/DC.
      For finer modern movements in need of a just a routine service, you may get by with 30 or 40 minutes of Scissor Sisters.
      IMG_0417.MOV
    • By Bev
      Hi,
        One problem i'm constantly facing is once the movement is running and I've got the dial and hands back on, I'm always struggling to remove the specs of dust from the underside of the crystal.  New crystals seems worse - as they appear to have a static charge.
      What are the tricks to ensure that the underside is clean before casing the movement?
      Rgrds
        Bev
    • By Mark
      I have just posted a new vid on YouTube. This one takes last weeks video a bit further and shows the basic operation of a Timegrapher timing machine.
    • It is very hard to see that line on my case.  But the ring must be there.  I attached a couple of pics.  One is the top of the case - you can see that the crystal came loose on one side.  I tried to get the same view you did in the other pic.  Not sure if you can see it.  So is it possible to push the ring out from inside? Also what is the best source for a new crystal?  Thanks much for your photo!
    • Welcome to WRT forum.
    • Hello, I have a problem with my ETA2801-2. Initially the watch was running great, but it was skipping while winding. I guess I made a mistake and pulled the train bridge in order to check the mainspring, afterwards I figured that wasn’t necessary. Anyway, after putting everything back together it was running with low amplitude and became impossible to regulate to anything over -120spd. I decided to pull the bridge again, and clean all associated parts in ultrasonic, and re-lubricate. Unfortunately nothing has changed, it still runs with low amplitude - about 230 and there is no way to make it run any faster than -120spd. What could be the reason behind it? Here is how it looks like on a time grapher.
    • Hi, I’m not new to the watch world by any means, but I’m not a pro neither. I like to occasionally work with my watches as a part of watch collecting hobby 🙂
    • You're very welcome.  Perhaps it would be an idea to send a pic to Rolex themselves and see what they have to say.  You might have to take the back off the watch and take a few more pics.  Would be worth a try.  If you do that, please let us know how you get on.
