double fusee bracket clock
rajeshvyas
Oh dear looks like it’s been in a fire. There is a James Corrie of London listed from 1832 to 1857 in Watchmakers & Clockmakers of the World Vol 2 by Brian Loomas. This is a late bracket clock as it doesn’t have any engraving on the back plate. So it’s about 1857. The poor thing is going to need a lot of restoring.
hi, many thanks for your valuable reply. i have recently restored it not fully but up to some extent keeping old ware and scratches all around! to my surprise the clock even so old started ticking after cleaning and re-fitting. it shows very precise workmanship by Corrie! the hammer strikes with full strength even after ages....pix attached. thanks/rajesh
hi, again i am back with one more query. i have one single fusee large size ONLY movement with counter weight engaged on the minute wheel. now, to start with i will have to first make minute hand and then fix the dial size, so is it possible to judge the length minute hand?
I would say that movement is from some advertising clock going by the weight. I wouldn’t be surprised if the minute hand is about 18 to 24 inches. Its going to be a trial and error regarding the hand. Something that fits is all you need to start with.
good if it can hold 18-24" at present i am testing with 0.8mm thick 12" long hand. if the result is good i will further increase the length to 20-24"
one more thing i would like to know while testing does it make any difference if i test it without pendulum? as per my knowledge pendulum regulates the speed and has nothing to do with the hand/counter weight-correct?
The greatest load will probably be somewhere around quarter-to-nine. You could just test it at the first few clicks of the fusee to check it can still run at the weakest portion of the wind (even though the fusee compensates for this to some extent). Driving the pendulum does consume energy (think about during recoil) so will need to be fitted.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
    • Hi wathweasol. I think it's made of brass. From the look of things, replacing the whole pusher as a set is beginning to be the way to go. Thanks. I'm thinking it could be just a tube and friction fit. I've taken another shot of the tube and posted here. Looks like just a tube fitted flush. Then, again, I have no experience in chronographs especially tubes and pushers. This one has no clips or washers to lock in the pusher in place. Coming from the outside, you'll have the button, spring and the stem inserted from the case and screwed in. The case holds the spring in place and the ridge at the other end of the stem keeps it from falling out of the case. Posted some pics here and an illustration to help. My sketch of how all the parts come in to play: Two different angles of the stem. Note the ridge near the slotted end that stops it falling out. This is an assembled piece of the one that was successfully pulled out. If it will have to be replaced, may I have some tips please on how to place an order, sizing, etc (Cousins, Esslinger,...) and on how to remove/install the pushers. My experience is just basic service with time only, day/date complications. Haven't had the opportunity to replace crown tubes and pushers. Thank you so much.
    • If you have no Powerpoint at Hand (but Libre-Office or whatever..), to get Access to the Videos in the pptx, make a Copy of the File, rename it to blabla.zip and unzip the File. Now in the Folder ppt/media you have all Pictures and Videos......   hope this helps some of us regards, Ernst
