Seiko SNXX51
8 hours ago, Tudor said:
Let’s get some good close ups of the bezel straight on, and at side angles. It probably can be removed...
Seiko 5 bezels can be removed but that requires a good press and precise dies. If the OP's intention is just to change its color he can simply polish it well without removing it. That requires a rotary tool or even better a bench polisher, and the proper felt wheels  and compounds.
I just want to get rid of the gold so this could be the best option. Thank you
I think you'd still want to remove the bezel to polish; the gold is most likely TiN and it will require some effort to remove...
If you do it in place, you may lose a lot of case before you are done with the bezel. If it IS gold, it will come off easily. But Seiko is known for pioneering TiN coating so that's where I'm betting.
I'd chuck the bezel in the lathe and polish it that way.
Just now, Hutchlee said:
Also is there a special type of bracelet I need for it? It is about 9mm lug to lug
Yes ,the original bracelet. That type of construction is called "case integrated" and is not a good choice if like to change to a strap or anything else.
This is complicated, but, MAYBE you can run an aftermarket "Oyster" style bracelet without the end links.
BUT, you'd need to mill in access notches on the underside of the last link to get the spring bars out, and you'd need the spring bars. The smallest Rolex ones I am aware of (for small Tudor ladies watches) are 11mm width, so those won't work.
You may be able to find 9mm flanged spring bars for ladies watches on the web...
I am thinking I can just reuse these adapters on the current bracelet to fit a new one
I can’t see that clearly in the picture but the springbars should absolutely be replaced. The “adapters” should be carefully checked to be sure you don’t dump the watch unexpectedly.
Im not able to measure the oyster mid link right now, but if it fit, it would open up a lot of aftermarket bracelets since it is widely copied.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
