Circlip material?
24h
A while back I made my own circlips/c-clips for some chronograph pushers out of music wire.
The results were OK, but now I'm needing some clips for a different watch with a much smaller groove for the clips.
I don't think I'll be able to make them by hand, and I haven't found anything small enough other than some M1.0 clips. These seem to be plated with something or have a black oxide coating. Probably not meant for watchmaking, but would this be OK to use?
Edited by 24h
7 hours ago, Marc said:
Thanks for the reply. I did see those, but I'm unsure about how much wiggle room I have between the cutout in the case and the O.D. of the clip (it retracts back into a small hole).
I suppose I could just order a full set or a few different sizes to test.
Edited by 24h
On 9/28/2020 at 12:55 PM, Marc said:
Any other ideas? 1.00mm ID fits into the groove, but the 2.0mm OD is too large and it does not allow the pusher to fully extend back out.
Needs something more like 1.5mm OD
Put the clip on a small enough screw and chuck it in the dremel. Spin it against a Swiss pattern file, checking the OD as you go.
You should be able to take a bit off. Give it a light smear with some silicone O ring lube (Molykote 111) to keep corrosion at bay.
Thanks, I will try that method when I have some time next week!
On the other watch, I documented this method to make the clips: https://www.watchuseek.com/threads/creating-a-chronograph-pusher-c-clip-how-did-i-do.5165357/
I thought it might be too small, but now I'm up for two challenges. ?
Just ordered some 0.008" music wire (0.2mm) to fit the smaller groove of this watch, so in reality it will be 1.40mm x 1.0mm x 0.2 mm
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
